I might clean the engine today if it stops raining any particular product you guys use to leave it looking like new? I was thinking of GUNK Foam. What do you guys think?
09 Camry Full Gen 6.5 conversion/4300K HID low beams/3000K HID Fogs/Borla exhaust/ 35 tint all around/Auto folding mirrors/Full led conversion/ K&N drop in filter/ Flux capacitor to make it go faster.
if it's plastic, remove it and clean it with a cloth. Like the cover. I got a few of it on my plastic cover and it kinda ruin the plastic finish.
yeah I am going to remove the engine cover to clean the engine it self.
Last time I cleaned the engine in the '03, I just sprayed cool engine liberally with Simple Greem and then gently misted it off with the hose. The car doesn't have any leaks, so there wasn't any real build-up. Mostly just road grit and pollen. I did go back after it dried off and spot clean a few things that actually require a cloth and a bit of attention.
2003 Camry LE - Phantom Grey Pearl
2009 Camry LE - Magnetic Grey Pearl
2006 Jeep Commander - Dark Khaki
The engine degreasers like Gunk, etc., will remove your painted lettering on your engine cover, if you have them... I would remove it and clean with a less aggresive cleaner...
I use Meguiar's Super Engine Degreaser, which I buy in bulk and mix in my own ratio's for my side business... Meg's also has an OTC product now that is in the Autozone, O'Reilly's type stores now, that is pretty good...
I haven't done the Camry yet this spring, that will be in a few weeks- but here is a before and after on my Explorer from last weekend which was a spray down with Ultimate Degreaser 4:1, light mist to rinse off, leaf blower to blow excess water off, and followed with Meguiar's HyperDressing at 10:1. Missed a spot under the MAF, but it came out decent.
i use simple green to wipe off all the parts, then follow up with black magic interior protectant, since it's too greasy for my interior i thought it did a great job sprucing up the plastic underneath the hood
After:
It look like tossed salad in there and you add dressing. The plastic looks good though. Think I might use this dressing see if it'll fix my plastic cover, I think the stuff I used ruin the glossy finish of the plastic.
Isn't the word "interior" means inside the passenger area and not under the hood? It's just different environment.
I use this ( http://imageshack.us/f/190/21266175.jpg/ ) from Walmart. Cheap, dissolves grease very well, and didn't hurt anything (but I do keep it off the paint).
Spray/rinse/repeat a few times, and hit with a soft long-bristled brush where possible, and it looks pretty good. It doesn't look "done" like some above, but it looks good enough.
btw, it looks blue in the picture, but it's actually a purple bottle.
'02 Highlander Ltd (mine)
'09 Camry LE (wife's)
I clean it with P21S TAW, agitate it, and spray it off. Then I dress it with 303 Aerospace Protectant.
1999 Toyota Avalon XLS
2006 Toyota Tundra Double Cab X-SP
2010 Lexus ES350 w/ Nav package
Originally Posted by rty
Six Camrys, one from each generation. In a temperature controlled alarm secured garage filled with Camry memorabilia. I just worry I might not be able to enjoy every Camry. So many Camrys so little time.
What I like about the Megs Hyper Dressing, is that it's water based, and different mixed ratios finish with different sheens. I buy it by the gallon, and mix separate spray bottles for different applications.
I use Simple Green and a hose. I run it til its at operating temp for +15 min then soak it with SG and let it sit for a couple minutes. Then I spray it off with the hose. If necessary I'll repeat or wipe/scrub really dirty stuff.
__________________ 06 NB tC - OG Team HAMSTER - SUPERCHARGED
