Keeping the engine bay clean? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2011, 06:42 PM   #1 (permalink)
View Lamski's Photo Gallery
Gen6 Keeping the engine bay clean?
What's the easiest and most effective way to clean and keep the engine bay clean. Do I need to get a steam cleaner? Im guessing I can't just spray degreaser and hose off... Don't want to cause any damage.
Lamski is offline   Reply With Quote
Old 07-11-2011, 07:25 PM   #2 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $335525
View glenn14's Photo Gallery
I use a degreaser and spray the engine block not the plastics rinse everthing off with a hose and attachment and try to keep the water away from the electrical components like the alternator etc. Dry everything with a cloth then amourall all of the plastic stuff like the valve cover etc. Here is a pic.
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
Old 07-11-2011, 08:33 PM   #3 (permalink)
muckdawg24's Avatar
View muckdawg24's Photo Gallery
Good question, I want to know too. I usually haven't cleaned engine bays but it would help come maint. time.
muckdawg24 is offline   Reply With Quote
Old 07-11-2011, 09:24 PM   #4 (permalink)
glenn14's Avatar
Did you read my post above w/pic ??? I use a mild degreaser spray the engine block, rinse off..I'll get a plastic bag and cover the alternator etc. I also use a plastic handle brush to get into the tough areas to scrub then rinse off.
I rinse the plastic engine cover..battery,air box anything plastic under the hoods to get rid of dust and sand etc. Then I wipe them down with a cloth and then use a dressing to keep the black shiny look..
Glenn
2009 Camry SE MODS:
Old 07-11-2011, 09:30 PM   #5 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
Glenn
Yup do that, make SURE to cover the alternator and let the engine cool down first before you spray water. Get a soft brush and scrub at the stubborn oil spots if you get your car oil sprayed. And once it dries up, put protectant onto the plastic parts. I use aerospace 303, my fav interior/plastic protectent. Depending on how anal you are you can just use a cloth to wipe it down, or get smaller brushes and what not to get every crack and crevice. And form here on, just maintain the engine bay so you dont let everything build up again.
For my after I initially clean it, (summer) I usuually just wipe the plastic down after I clean my interior since im using the same product. Once I get the car oil sprayed though, after winter, during spring I do a full clean up again.
CamrySExxx is offline   Reply With Quote
Old 07-11-2011, 10:24 PM   #6 (permalink)
I Eat Accords! W_(^_^)_W
my.rims.are.stock's Avatar
Gameroom cash: $114800
View my.rims.are.stock's Photo Gallery
I also wrap my K&N SRI filter in a couple of plastic wal-mart bags to make sure it doesn't get soaked. If you are still stock, I would make sure you didn't spray any water into the RAM opening on the front.
I also use this:
http://www.amsoil.com/storefront/apf.aspx
my.rims.are.stock is offline   Reply With Quote
Old 07-11-2011, 10:37 PM   #7 (permalink)
lostsignal's Avatar
View lostsignal's Photo Gallery
I personally don't see a need for anything more than an APC, towels, and maybe some degreaser. I just use an APC and towels. Then cover the plastics in 303.
If I could do it any way I wanted I'd use a steamer for sure. I wouldn't put a hose anywhere near it.
lostsignal is offline   Reply With Quote
Old 07-12-2011, 04:10 PM   #8 (permalink)
CTB727's Avatar
Gameroom cash: $583435
View CTB727's Photo Gallery
I use a steamer, Meguiar's APC+ diluted 4:1, towels, and dress it with 303 Aerospace protectant. MUCH better than Armor All. Guaranteed.
1999 Toyota Avalon XLS
2006 Toyota Tundra Double Cab X-SP
2010 Lexus ES350 w/ Nav package
Originally Posted by rty View Post
Six Camrys, one from each generation. In a temperature controlled alarm secured garage filled with Camry memorabilia. I just worry I might not be able to enjoy every Camry. So many Camrys so little time.
CTB727 is offline   Reply With Quote
Old 07-20-2011, 11:05 AM   #9 (permalink)
View racerchoi's Photo Gallery
I usually have a car wash steam clean it every summer for $40. Looks sharp and polish lasts about 8-9 months.
racerchoi is offline   Reply With Quote
