Originally Posted by Justdiscovering
Today I bought a wenn random orbital buffer from the goodwill for 6 dollars, is it safe enough to use for a first timer like me? Or should I have went to mcdonalds with my 6 dollars and got lunch?
PS. I would post this on the car care forum but no body really goes on there..
what should the motion be?
that's a good price, and it may last you a very long time. i only use mine AFTER i have applied and buffed the wax all by hand. i use my buffer as a "final" buffing.
i use a circular motion, then i go straight lines, no matter how i do it, i always overlap.
DO NOT press down on the buffer. the weight of the buffer alone is ENOUGH for it to work. as mentioned however, so do not press down.
make sure you buy the correct buffing pads, one should last you a very long time, if all you do is buff with it. once you start using the buffer to apply then take off the wax, you need to clean it, and that takes the life away from the pads. mine i have right now are about 10 years old..!! still as new as day number one..
good luck, take your time, go slow, do not press down, be careful of the cord....
