How to keep engine room clean? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2005, 04:32 PM   #1 (permalink)
The Carpenter on Tacoma
Gin-Coma's Avatar
View Gin-Coma's Photo Gallery
Canada How to keep engine room clean?
To All Taco Freaks!
I need your advice how to keep the engine room and the engine clean all the time!!
Can I just wash it away? I guess there are things I should know before do it,,,
Silver Tacoma Prerunner 05 DBL cab TRD SP
Since Jul.18th.2005
Gin-Coma is offline   Reply With Quote
Old 08-07-2005, 05:51 PM   #2 (permalink)
05 Speedwayblue X-runner
rpmspeedyBlue's Avatar
View rpmspeedyBlue's Photo Gallery
[QUOTE=Gin-Coma][size=2]To All Taco Freaks!
I use simple green and water when it starts to get dirty, But if you get it really dirty use a pressure washer. Cover the alternator with a plastic bag.
rpmspeedyBlue is offline   Reply With Quote
Old 08-07-2005, 06:01 PM   #3 (permalink)
Gin-Coma's Avatar
Thanks for the answer!
Since Jul.18th.2005
Old 08-07-2005, 10:40 PM   #4 (permalink)
CARDS RULE
Bluzman's Avatar
View Bluzman's Photo Gallery
I would get with Pb2themax, he is THE MAN when it comes to detailing!!
Silver Double Cab, 4x4, TRD Sport
K&N/AEM Hybrid Intake
Magnaflow Exhaust
Split Second PSC1
Bluzman is offline   Reply With Quote
Old 08-08-2005, 09:07 AM   #5 (permalink)
remelad's Avatar
View remelad's Photo Gallery
I use Purple Power from NAPA here for cleaning and degreasing engine compartments. Similar to Simple Green.
You do not have to cover the alternator either. Just use some common sense and don't stand there pressure washing items like that for 15 mins a shot...
Chad
ASE MASTER CERTIFIED TECHNICIAN
remelad is offline   Reply With Quote
Old 08-09-2005, 02:58 AM   #6 (permalink)
MODIFICATIONS MUST B MADE
JUNGLEMAN's Avatar
View JUNGLEMAN's Photo Gallery
I use the turtle wax tire stuff on the plastic & hoses to make `em shine after I wash it
I spray it all over the engine compartment just use common sense like they said
it works excellent on the running gear too
Way too much stuff.........
http://www.cardomain.com/ride/828118
JUNGLEMAN is offline   Reply With Quote
Old 08-09-2005, 03:05 PM   #7 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
I'd be carefull with the Simple Green. If you do use it on plastic parts, be sure to dilute it. Otherwise it can leave residue behind.
I keep my truck pretty clean, so on the engine compartment I use car wash soap and water on an old wash mit. Some dirt and grease won't really leave unless you actually rub it with a mit or brush. Ever take a dirty car through the touchless car wash, and then later when the car was dry you could still see lots of dirt residue and streaks? To really clean it, you have to touch it.
For places that I can't reach I use a 1:2 dilution of Simple Green and water.
A steam cleaner also works great, but I haven't bought one of those yet.
Then to dress up the engine compartment I use Eagle One Interior/Exterior protectant on a foam pad or swipe. It's not real greasy, so dirt and dust won't stick to it as much. On the tires I use a more oily protectant, like Mothers FX Tire Care.
Pb is offline   Reply With Quote
Old 08-09-2005, 08:30 PM   #8 (permalink)
Gin-Coma's Avatar
Thank you to all!!
I am so glad that I found this web site
Since Jul.18th.2005
Old 08-11-2005, 02:51 AM   #9 (permalink)
View kpagel's Photo Gallery
I just pressure wash it every now and then to keep it from getting dirty. Then I rinse (quickly) with deionized water to prevent spotting (so my lazy ass doesn't have to dry). Then I protect and enhance black plastic parts with 303 Aerospace protectant. Basically, if you can keep it from getting dirty in the first place, you make your job a lot easier.
kpagel is offline   Reply With Quote
Old 04-09-2006, 04:13 PM   #10 (permalink)
Pb
Pb's Avatar
+1 on the 303 aerospace.
Old 04-09-2006, 05:14 PM   #11 (permalink)
View thoughthard's Photo Gallery
Steam cleaner x2
thoughthard is offline   Reply With Quote
Old 04-09-2006, 10:03 PM   #12 (permalink)
Pb
Pb's Avatar
Steam cleaners work great, but I think they should only be necessary on older or neglected engines. On newer vehicles, a regular rag and cleaner will work fine if you give your engine compartment about 10 minutes worth of attention, once a month.
Old 04-10-2006, 05:40 AM   #13 (permalink)
View deff808's Photo Gallery
Thanks for the tip! I need to clean mines....
deff808 is offline   Reply With Quote
