Freezing in Orange County :o ...
The car will run by itself no problem and does not try to die out unless I put into drive but then a tap of the gas gets it back.
I have a remote starter in the car and can hit the button and it starts on its own without a broblem but no more than 20 seconds later it goes into it's slightly rough idle and the missing begins. When I drive the car around a bit and the engine warms up, it starts to purr like a kitten and runs great. I have a slight hesitation when I hit the gas but this has been there for several years and the last time I took her to Toyota they could not help. Reason number one why I don't want to take her to Toyota...
Where is the Idle Bypass located so I can check it out to see if maybe????
Jeff
