you can use an msd blaster 2 coil as well...... the resistances are very close to those of a 4age coil.
are you sure your ignitor is wired in correctly? and that the magnetic pickups for the dizzy are wired in correctly? and are you sure your base timing (which needs to be set with the ecu jumpered) is correct?
also, did you check the timing belt before the motor went in? if it had jumped a tooth on the belt that could be limiting you as well.
