Originally Posted by toyotaspeed90
you can use an msd blaster 2 coil as well...... the resistances are very close to those of a 4age coil.
are you sure your ignitor is wired in correctly? and that the magnetic pickups for the dizzy are wired in correctly? and are you sure your base timing (which needs to be set with the ecu jumpered) is correct?
also, did you check the timing belt before the motor went in? if it had jumped a tooth on the belt that could be limiting you as well.
Well i just tried another coil @ ignitor, no go, still same problem
Well pretty sure ignitor wire right, just one plug and two leads to positive and negative
What do you mean by ecu base timing ? you mean factory timing ? i have redone the cams and pully and they lined up cams with their dots and lined up pully with Top Dead centre on piston 1 and 2
What do you mean by magnetic pickups on the dizzy ?
anyone think ecu be limiting it ? got stuck somehow ?
