Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
View Single Post
Old 11-30-2005, 04:28 PM   #12 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
"High Tech Misfit" <me@privacy.net> wrote in message
news:pan.2005.11.30.21.51.01.762171@hightech.misfit...[color=blue]
> Ray O wrote:
>[color=green][color=darkred]
>>>>Have the timing belt checked. It may be getting loose.
>>> Ok thanks! I'll keep it posted on here!
>>> Message posted via CarKB.com
>>> [url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200511/1[/url][/color]
>> You're welcome! The timing belt should be changed at 60,000 miles any
>> way.[/color]
> I thought that version of Corolla had a timing chain, not a belt?[/color]
It sure does! To the original poster, forget the timing belt advice from
me.
Next steps:
Does the car make noise when moving or when sitting still? How about in
drive or reverse and sitting still? Does the noise change with engine speed
or with vehicle speed?
Can you hear the noise with the hood open? If so, from where? Behind the
timing cover?
Ray O
correct the return address punctuation to reply
