Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
View Single Post
Old 11-30-2005, 05:40 PM   #13 (permalink)
Jessica via CarKB.com
Guest
Posts: n/a
View Jessica via CarKB.com's Photo Gallery
Re: Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
Ray O wrote:[color=blue][color=green][color=darkred]
>>>>>Have the timing belt checked. It may be getting loose.
>>>> Ok thanks! I'll keep it posted on here![/color][/color]
>[quoted text clipped - 3 lines][color=green]
>> I thought that version of Corolla had a timing chain, not a belt?[/color]
>It sure does! To the original poster, forget the timing belt advice from
>me.
>Next steps:
>Does the car make noise when moving or when sitting still? How about in
>drive or reverse and sitting still? Does the noise change with engine speed
>or with vehicle speed?
>Can you hear the noise with the hood open? If so, from where? Behind the
>timing cover?[/color]
The car makes noise mostly when still...in drive, idle, and reverse the most
but not when in netural. Once I get driving down the road it still makes the
noise for a while and quiets down after the car gets warmer but is still
making the noise. It sounds like a grumbling noise when sitting in the car
but when I have the hood open it sounds like a vibration. When I go faster,
vehicle speed, the noise is hardly there at all. With the engine speed, just
sitting still, the sounds fades away a little bit as well. The noise seems to
be coming from the belt/alternator area but I can't seem to pin point it.
Message posted via CarKB.com
[url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200511/1[/url]
