Re: Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
Jessica via CarKB.com wrote:
[color=blue]
> The car makes noise mostly when still...in drive, idle, and reverse the most
> but not when in netural. Once I get driving down the road it still makes the
> noise for a while and quiets down after the car gets warmer but is still
> making the noise. It sounds like a grumbling noise when sitting in the car
> but when I have the hood open it sounds like a vibration. When I go faster,
> vehicle speed, the noise is hardly there at all. With the engine speed, just
> sitting still, the sounds fades away a little bit as well. The noise seems to
> be coming from the belt/alternator area but I can't seem to pin point it.[/color]
I'm not 100% sure, but it's a possibility...
Have someone listen from outside the car especially when you have it in
reverse or when idling. If it sounds like a metallic rattle, the problem
is a loose heat shield. I had similar symptoms with my Honda Accord not
too long ago. The rattle did sound like a grumbling sound from inside.
