Re: Toyota Corolla 2002: Noise when car is started, in drive, and in reverse
"Jessica via CarKB.com" <u16217@uwe> wrote in message
news:58281aae760bc@uwe...[color=blue]
> Ray O wrote:[color=green][color=darkred]
>>>>>>Have the timing belt checked. It may be getting loose.
>>>>> Ok thanks! I'll keep it posted on here![/color]
>>[quoted text clipped - 3 lines][color=darkred]
>>> I thought that version of Corolla had a timing chain, not a belt?[/color]
>>It sure does! To the original poster, forget the timing belt advice from
>>me.
>>Next steps:
>>Does the car make noise when moving or when sitting still? How about in
>>drive or reverse and sitting still? Does the noise change with engine
>>speed
>>or with vehicle speed?
>>Can you hear the noise with the hood open? If so, from where? Behind the
>>timing cover?[/color]
> The car makes noise mostly when still...in drive, idle, and reverse the
> most
> but not when in netural. Once I get driving down the road it still makes
> the
> noise for a while and quiets down after the car gets warmer but is still
> making the noise. It sounds like a grumbling noise when sitting in the car
> but when I have the hood open it sounds like a vibration. When I go
> faster,
> vehicle speed, the noise is hardly there at all. With the engine speed,
> just
> sitting still, the sounds fades away a little bit as well. The noise seems
> to
> be coming from the belt/alternator area but I can't seem to pin point it.
> Message posted via CarKB.com
> [url]http://www.carkb.com/Uwe/Forums.aspx/toyota/200511/1[/url][/color]
Some late model Corollas had drivetrain noises that concerned some people.
The best way to tell if that is the noise is to take it to a dealership and
have someone there listen to it.
If the noise is coming from under the timing cover then a loose timing chain
tensioner is a possibility.
Ray O
correct the return address punctuation to reply
