Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - TECH: Oil odor 2003 Vibe 1.8l
View Single Post
Old 12-01-2005, 04:57 PM   #3 (permalink)
Wes
Guest
Posts: n/a
View Wes's Photo Gallery
Re: Oil odor 2003 Vibe 1.8l
I am due for another oil change this weekend. I am going to take it back to
them and mention the odor. I was leaning towards the PCV myself.
Thanks
"Ray O" <rokigawa@tristarassociatesDOT.com> wrote in message
news:c162f$438f6af1$44a4a10d$14364@msgid.meganewsservers.com...[color=blue]
> "Wes" <paigesdad@verizon.net> wrote in message
> news:DnJjf.421$N%1.381@trndny07...[color=green]
>> Hi all,
>> Just wondering if I can get some insight into a problem that has
>> developed with my 03 Vibe GT. Let me start by saying that I have never
>> had any issues with the vehicle right up to 100K. The car was due for an
>> oil change just after it turned the century mark. I took it to a local
>> Monro Brake and Exhaust franchise. This was the first time they had done
>> an oil change for since since the vehicle hit 50k. From the moment I
>> drove the car away, I have had an oil odor coming from my air vents. I
>> initially thought they may have simply dripped some oil onto the engine
>> and it would just burn off. It has now been 3000 miles and the odor
>> persists. I check ed the drain plug and filter and they are both dry.
>> There is also no leak that I can see (nothing under the car after its
>> parked). It smells like a crankcase odor and was not there before the oil
>> change. Is there anything I should be considering as the culprit?
>> Thanks in advance for any info
>> Wes[/color]
> I would consider the place that changed your oil as the culprit. Check
> for a loose PCV valve or hose. It is possible that they disconnected a
> hose when they checked your air filter.
> Ray O
> correct the return address punctuation to reply
>[/color]
