'91 Engine problem
Does anyone have any advice? Here's the rundown:
I was on the highway doing 70mph, when the check engine light came on and the car died.
The battery has plenty of juice left.
The starter cranks just fine.
I tested electrical, and the distributor gets power.
When I turn the belts by hand, everything looks sound.
I removed the distributor unit, and found no broken gears, the shaft spins ok.
However, the piece that the distributor coupling attaches to inside the engine does not rotate when the drive belt does.
Am I completely missing something?
I checked all of the fuses (except for the ones that aren't transparent) and they are fine.
If I am due for some major mechanical work, would it be worth my money to go for a new (or reconditioned) engine?
Can I get mounts for a more powerful engine? I figure if I'm going to do any major modding now might be a good time to start.
Any suggestions are greatly appreciated!!!!!
thanks -tim
