A more serious rim width question for a gen 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2005, 12:26 PM   #1 (permalink)
View MattSWE's Photo Gallery
ok ok, the whole 20's on a gen 2 thing was a bad idea. But I currently have 17 by 7.5's with 40 series tires on my 91. I want to upgrade to a 18" rim but with a width of 8, instead of 7.5. My tire size would have to be
215\35\18 for them to fit properly
how could I get a 8" to work on my car?!? What kinds of mods would I have to do?
thx a bunch guys.
MattSWE is offline   Reply With Quote
Old 11-22-2005, 02:22 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Depends on the offset. Me and another guy here (da_horse) test fit rims on his car, and it proved that 8" rims don't fit without a)a spacer or b)a high offset. Either of which would require the guards to be rolled.
Personally, i've found 7" rim to be a "perfect" fit with a +38 offset. No rubbing, and clears the strut fine. I'm running 215's on my 17x7's.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-22-2005, 03:10 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
spacer+higher offset = the same as b4.
im guessing youd need something with a WRX application (which in 8" wdith you wont find much as the WRX is the closest car with teh same (very high) offset)
i see problems with suspension travel.. youd have to keep it frop going any further then under the lip flare of the wheel guards.
custom short stroke struts
if yroeu dead set, get some custom 2 or 3 peice wheels made to suit.
terrastrife is offline   Reply With Quote
