89 camry stalling while driving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2006, 10:21 PM   #1 (permalink)
View ericksonm's Photo Gallery
The car just shuts off while drving and I could easily get rear ended
All I did to the car was change oil .. then cleaned out the engine with degreaser....
The car would start up and idle fine but after driving it for awhile it would just shake then shut off. the coolant is at the right level and so is all the other fluids. Why would it just turn off while driving and keeping the gas on the pedle?
'01 Celica, '00 Land Cruiser, '95 Camry, '87 Camry
ericksonm is offline   Reply With Quote
Old 01-13-2006, 11:54 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $355745
View atobe's Photo Gallery
egr valve stuck ? i really don't know
Old 01-14-2006, 12:03 AM   #3 (permalink)
I've been contacting friends and searching on the net.. it seems it could possibly be the alternator? http://www.misterfixit.com/alterntr.htm
Old 01-14-2006, 12:12 AM   #4 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Its not your altenator. It sounds like it could be the coolant temperature sesor, i've heard here that it can cause your engine to die while the engine is fully warmed up. Another thing that might be happening is that your fuel pump is faulty which means that it quits when it wants to and then start working again later. Have you changed your plugs lately?
V6LE_CAMRY is offline   Reply With Quote
Old 01-14-2006, 12:19 AM   #5 (permalink)
View Gary_602Z's Photo Gallery
Did you get engine degreaser on any ignition parts when you sprayed your engine?
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 01-14-2006, 12:20 AM   #6 (permalink)
I probably got the sparks wet when rinsing off the degreaser
Maybe it's the plugs since it's been so long since I've gotten them changed.
When it starts to die down I'd move the automatic into Neutral ..tap the gas a bit.. then put it back into Drive and it stays on okay.. but driving a car that just dies isn't so fun having the feeling of getting rear ended
Old 01-14-2006, 12:22 AM   #7 (permalink)
argh I think I did get some on the ignition parts
Old 01-14-2006, 11:05 AM   #8 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Erik,
If you still aren't having any luck, check for carbon tracks under the distributor cap. I've had that problem in the past after spraying water on an engine.
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 01-15-2006, 04:32 AM   #9 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $261775
Its your ignition coil...
If you can keep it dry, you'll be fine. If it gets wet, it shorts out through the hairline cracks that develop on them over time. This is a standard problem on the gen2 Camrys.
There are two solutions:
Don't get the engine bay wet
or...
Get a new ignition coil. Its inside the distributor cap.
Good luck.
-Charlie
white90dx is online now   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
Personal Camry Websites - POST HERE Silver Streak Camry & Solara Lounge 193 08-03-2011 12:56 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 11:55 PM
94 stalling camry Garvin021 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-20-2005 10:09 PM
