Help with 86 camry fuel problems. Pretty please. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2006, 12:53 AM   #1 (permalink)
View supernoob's Photo Gallery
Gen1 Help with 86 camry fuel problems. Pretty please.
So here's the story. My fathers 86 camry died yesterday. I eventually found that the fuel pump was not working. I tested the leads to the pump and they were not getting power (the blue with black stripe and white with black stripe) I ended up running new wires from the fuel pump relay under the hood to the tank. So now the fuel pump runs and makes 65psi max. Now the injectors aren't opening. The cold start injector works but the others won't do their thing. I also tried to pull trouble codes by jumping the T and E sockets in the diagnostic port but the engine light just flashes steady about every 2.5-3 seconds.
Questions
Should the blue/black stripe wire get power when the ignition is turned on? I checked at the fuse block and the tank and nothing.
Does something else run off the fuel pump circuit?
What does that engine light flashing mean?
Do I have any idea what I'm doing?
Can anybody help? You will be my hero for ever and will get a big cookie.
Thanks in advance.
supernoob is offline   Reply With Quote
Old 01-17-2006, 01:07 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $395785
View RningOnFumes's Photo Gallery
um....count the flashes to get your code
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 01-17-2006, 01:15 AM   #3 (permalink)
Just one flash. About every 2.5 seconds.
Alternator/Electrical problems on an '86 Camry McTimson 1st & 2nd Generation (1983–1986 & 1987-1991) 6 12-04-2004 04:00 PM
Problems with fuel Project Lazarus Archived Corolla threads 5 06-09-2004 10:39 PM
1999 Camry problems nonstop only 28,800mi neuspeed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-04-2004 01:03 AM
fuel problems and other problems... trdG Camry & Solara Lounge 0 12-22-2002 11:36 PM
