1990 camery vibration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2006, 07:16 PM   #1 (permalink)
View stephan's Photo Gallery
Hi. I have a 1990 camry 4 cyl, auto trany that vibrates at idle and while going in reverse. I have changed all the mounts. Once im driving there is no vibration, Its not a miss or dead cyl, any help would be great
stephan is offline   Reply With Quote
Old 01-19-2006, 10:44 PM   #2 (permalink)
View jrock80's Photo Gallery
I think this is just normal. Mine vibrates a lot too when I am just sitting at a light. I havent changed the mounts or anything because I dont know how. I did already change all of the normal maitenance items such as plugs, wires/cap, rotor, 02 sensor, fuel filter, etc. Car ran better after that but the vibration at idle is still there. The car runs good and just like you said doesnt do it once your moving.
jrock80 is offline   Reply With Quote
Old 01-20-2006, 04:29 AM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $261675
Pop it into neutral when you are at a light... that should make most of the vibration go away. Its pretty much normal for an old car... as long as the vibration is constant and not to bad.
-Charlie
white90dx is online now   Reply With Quote
Old 01-20-2006, 08:20 AM   #4 (permalink)
Even in neutral mine still has the vibration, but it is worse in drive.
Old 01-20-2006, 11:10 AM   #5 (permalink)
95% Biker / 5% Driver
Digger1's Avatar
View Digger1's Photo Gallery
Jock,
My old Gen 1 I-4 Camry had a similar problem. Sometimes I would boost the idle speed a bit to lessen the vibration.
Good luck!
Digger1
"If you don't understand the technology you depend upon, you will someday be a victim of that technology."
Digger1 is offline   Reply With Quote
Old 01-20-2006, 12:36 PM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $355745
View atobe's Photo Gallery
there's a screw on the throttle body pull the brakes put it in D up the idle a lil bit with a screw driver it'll help a lil bit
Old 01-20-2006, 03:22 PM   #7 (permalink)
Gameroom cash: $275055
Try cleaning the throttle body. That should help a bit.
Mike
Old 01-20-2006, 07:47 PM   #8 (permalink)
Thanks for all the replies. By the sound of it I guess its pretty much normal. The camry has 166,000 miles on it, it still drives fine and it gets a seady 28 - 30 mpg. So ill just live with it. I have had this car since new, but my wife drives it mostly and the vibration seemed new, but then again maybe its just me
Old 01-21-2006, 03:13 PM   #9 (permalink)
made it over 300K!
View 90 Gen2's Photo Gallery
raise the warmed up, in drive, idle speed to aroun 950-1050.
if your engine is not smooth at 1000rpm, say in neutral, then you need to look at why that is (likely ignition problems)
if you adjust it like that, the car will at least idle smoothly when cold (and the computer further raises the idle) so at least when you first start driving you won't feel like something must be wrong with your car! The downside of this is increased harshness when you shift into Drive or Reverse, but the gargantuan clunk has not seemed to further deteriorate the mounts or harm the drivetrain in our car in 3+ years of this type of operation.
90 Gen2 is offline   Reply With Quote
Old 01-22-2006, 12:25 PM   #10 (permalink)
I think I will just leave it alone. The car is running well, took a trip yesterday of about 200 miles and returned just over 30MPG including city and highway driving. So I dont think its a tuning issue more just an annoyance.
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 11:53 PM
steering wheel vibration gone! toytaco970 2nd Generation (2005+) 0 11-16-2005 11:12 PM
Idle Vibration and Automatic Transmission Roll Back Doones 1st Generation (2003-2008) 4 08-04-2004 11:55 PM
