90 Camry Vibration @ Idle... help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2006, 07:32 PM   #1 (permalink)
View toyo22r's Photo Gallery
I have a 1990 Camry that I just got going. I bought it with a bad auto tranny. I replaced and it runs very well, however I have this somewhat anoying vibration at idle. In Park, you can feel a slight virbation from the motor. When its in Drive or Reverse, the vibration is much worse. Motor mounts appear to be ok. In other words you can see the motor vibrating yet when you place your hand on the mount you dont feel it... so the mounts are absorbing the virbrations... but why do i feel it in the brake pedal and in the seat? Any ideas on what to check?
Thanks in advance...
Paul
toyo22r@hotmail.com
toyo22r is offline   Reply With Quote
Old 02-12-2006, 10:45 PM   #2 (permalink)
View Ruchi's Photo Gallery
I got the vibration too
I'm not certain, but I'm going to keep my foot on the brake while in drive, and see if it's RPM related. If it improves at around 1200 RPM or so, I'll see if I can set the idle control screw so that it idles around 1000. Not sure if any of this is possible.
Ruchi is offline   Reply With Quote
Old 02-12-2006, 11:16 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $261475
Sounds pretty normal to me... Welcome to an older car... That is, if the mounts are truly ok.
You can also do tune-up items on the car to smooth things out a bit.
-Charlie
Personal Camry Websites - POST HERE Silver Streak Camry & Solara Lounge 193 08-03-2011 12:56 PM
2002 V6 Camry won’t idle after battery change\cleaning of terminals. RenoJim 5th & 6th Generation (2002-2006 & 2007-2011) 0 08-18-2005 08:13 PM
97 camry idle problem sameer2601 3rd & 4th Generation (1992–1996 & 1997–2001) 6 07-12-2005 07:20 AM
92 Camry 2.2 Black smoke & won't idle Help cato47 3rd & 4th Generation (1992–1996 & 1997–2001) 5 06-21-2005 12:44 AM
'90 V6 Camry -- Compression? and Plugs question 1966CL77 1st & 2nd Generation (1983–1986 & 1987-1991) 2 11-18-2004 10:18 PM
