Originally Posted by atobe
you're going to have to bleed your brakes afterwards
Theres a secret to not having to bleed the brakes.
Brake lines go through a mount on the strut. Theres a clip (cam clip) that holds the brake line.
1. Remove the cam clip.
2. With a hacksaw blade cut a slit in the mount.
3. Bend the mount with a pair of pliers.
4. Remove brake line.
If you do it this way, you don't open up the brake system. So you don't have to bleed the brakes.
Look at the strut labeled FR (front right) in the pic below. Notice how the mount for the brake line is cut and is bent.
