90 Camry Tuneup questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2003, 08:40 PM   #1 (permalink)
Call me DR. DIY or SHGUN
View Bigshoguns's Photo Gallery
Okay sorry for a dumb question but how do i replace my spark Plugs. my dad's 90 cam has 175k miles on it and i think it's time for a tune up(even thou he thinks it's not). and is that all or do i also need to change the PVC valve. just need some steps. and another thing.. how can i make a Cuztom Intake for my GEn 4. what type of Mandrel bent pipes do i need and hoses and filter.
THANKS IN ADV.
SS.
GOT A NEW ALPINE HEAD UNIT, MATRIX EXHAUST, AND STILL WORKING ON RIMS.
Bigshoguns is offline   Reply With Quote
Old 01-05-2003, 03:31 AM   #2 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
Re: 90 Camry Tuneup questions
THANKS IN ADV.
SS.
you just take off you spark plug wires by twisting them and pulling them up, then you get spark plug socket; stick it down the hole, put it on the spark plug and turn
djprefix is offline   Reply With Quote
Old 01-05-2003, 09:35 AM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Don't forget to use a bit a anti-sieze thread stuff.
Phi is offline   Reply With Quote
Old 01-05-2003, 12:07 PM   #4 (permalink)
thx guys for u help.. do prefer ne spark plug brand. Plat or Iridium
Old 01-05-2003, 02:37 PM   #5 (permalink)
ryan7373's Avatar
View ryan7373's Photo Gallery
I used NGK laser welded platinum plugs when I changed mine... the Denso's I pulled out of mine were oxidized pretty bad. The shop where I bought my plugs also said to change the ignition wires also if that hasn't been done in awhile.... they're pretty cheap anyways. Buy an insulated socket and use a 6in extension. Good Luck.
'98 CAMRY LE I-4
-is300 wheels [FOR SALE in HOUSTON]
ryan7373 is offline   Reply With Quote
Old 01-05-2003, 03:22 PM   #6 (permalink)
thanx ryan.. i will do that and will keep in touch about it. i also have a 98 le i4. ironic. hehe
Old 01-05-2003, 05:54 PM   #7 (permalink)
ryan7373's Avatar
cool. I'm relatively new at this all but I'm learning as I go. :wink:
'98 CAMRY LE I-4
Old 01-05-2003, 09:26 PM   #8 (permalink)
View VZV21's Photo Gallery
SOme other things:
Tune-up:
Remove the distributor cap and check the resistance of the terminal inside the cap to the end of the wire. The resistance should not exceed 25 k-Ohms. If it does, you'll need a new cap/wire set. A new distributor rotor is good also.
PCV:
I don't think there's a PCV valve in the 3s-fe
tan
-Retired: 88 Camry V6 5-speed & 84 Corolla Sedan
-Now driving 02 Golf TDI (hey I got a 80 mile commute)
VZV21 is offline   Reply With Quote
