Auto trans problems -- gen2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2006, 04:48 PM   #1 (permalink)
View Mr. Photog's Photo Gallery
2nd Generation Auto trans problems -- gen2
Hi there. First post -- 91 camry; 4 cylinder, auto; K&N but otherwise stock.
So the automatic transmission died the other night. Drove 100 miles or so, parked it and came back 2 hours later. Made it around the corner, and the re was a huge KLUNK! and we ground to a halt.
My girlfriend said "It sounds like it threw a rod", and she was right -- it did sound about like that. But the motor was fine; the transmission isn't.
The symptoms, as far as I can tell: after about 100 yards, will suddenly slow the car and motor to a crawl. Can't shift into neutral at that point -- you can put the shift lever there, but the car won't roll.
After some time, it will move -- but will quickly lock up again.
Any idea what's wrong? What to check?
I'm a decent mechanic -- I've put close to 100k on a manual trans I rebuilt in another car -- but clueless about automatics.
Thanks for the help, everyone.
Matt
Mr. Photog is offline   Reply With Quote
Old 03-01-2006, 04:59 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Welcome.
Honestly, these sorts of things are quite hard to diagnose without tearing it down. (unless your an auto trans mech and have had the problem before). By hearing a "clunk", it sounds fairly serious, and i don't think simply checking the fluid or the filter inside is going to tell you anything (apart from maybe metal shaving :P). Perhaps, check the shift solenoids, and also the NSS/shifter mechanism on the front to see if it's actually shifting into gear properly.
Goodluck
JetspeedCamry is online now   Reply With Quote
auto trans choices for 97 silkydraws Archived Corolla threads 12 11-26-2005 10:34 PM
How bad is the Auto Trans on tC? serith 1st Generation (2005-2010) 27 03-03-2005 12:08 AM
Auto tranny having problems going into 4th machman Camry & Solara Lounge 5 12-17-2004 08:53 AM
auto trans od question mr2_wump MR2 Forum 0 09-22-2004 01:30 PM
