'89 3S-FE no start. help diagnose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2006, 05:44 PM   #1 (permalink)
View capoeta's Photo Gallery
First post...
Trying to help brother with his Camry "no start" problem. Getting no spark after performing timming belt change.
using Haynes manual. I determined correct timming. turned engine 2-3 times and timming marks look good.
I then moved to check Pick up coil and I get strange resulst.. Checking for resistance, I get a reading for a second and then it dissapears from the screen (digital meter). Both combinations (G,G- & NE,G-) give me the same results. Both flahs readings between 130- 180 but dissapear after a second.
I then checked the coil and I get the following:
Primary coil resistance: 0.8
Secondary coil resistance: 9.4
Any help you guys can throw my way is greatly appreciated.
I'm mostly familiar with "domestic Ford" engines and am having a difficult time with this car.
Thanks in advance for the help.
Art
capoeta is offline   Reply With Quote
Old 03-05-2006, 02:40 AM   #2 (permalink)
Pabloso
project92camry's Avatar
View project92camry's Photo Gallery
Hows The Fuses ?? Did U Touch Anything That Had To Do With The Ignition System When U Were Changing The Timing Belt, Like Wires ?
And Did U Get Any Touble Code ??
project92camry is offline   Reply With Quote
Old 03-05-2006, 07:58 PM   #3 (permalink)
Buck Foston
Location: Connecticut, where you pay WAY too much for WAY too little
View AvalonMan96's Photo Gallery
It might be your ignitor. My old 1988 Camry with a 3SFE had that problem, it would crank and crank without turning over. This happened at roughly 156K miles and luckily in my driveway.
Had that replaced, and had no starting troubles since then until I sold the car at 210K miles.
It looks like a little silver box directly to the side of the battery.
Hope this helps, good luck!
96 Avalon XLS--02 Tundra Access Cab SR5 V8 4WD
"Gen 2--The only Camry that matters"
AvalonMan96 is offline   Reply With Quote
'85 rolla no start powerslide713 Older Generations (1969-1987) 10 04-08-2008 11:07 PM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 05:49 AM
89 Celica GT conv won't start briannc Celica Forum 2 08-07-2004 02:10 AM
89 camry 4cyl. wont' start. Please help ScottaWhite 1st & 2nd Generation (1983–1986 & 1987-1991) 14 07-22-2004 02:35 AM
Problem 89 corrola, will not start CamryDX Archived Corolla threads 4 07-10-2003 01:54 AM
