1990 Tachometer - help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2006, 10:27 PM   #1 (permalink)
View QuietRonin's Photo Gallery
I'm looking for an in-dash tachometer, or a conversion kit, for my 1990 Camry, which came originally without a tachometer. I've been searching all night (and most other nights, too) and haven't found anything.
Does anyone know of a place where I can get my Camry a tachometer?
Much help would be appreciated.
QuietRonin is offline   Reply With Quote
Old 05-21-2006, 12:05 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
find a gen2 cluster that has a tach, straight swap.
pretty sure all of the LE's had tachs and 5spd models had them too. Just make sure you get one from a car that has the same engine as yours - ie 4cly needs 4cly cluster.
check ebay, usually a few on there.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 05-21-2006, 01:40 AM   #3 (permalink)
Ah, thanks.
Mine's a 5 speed and is without a tach. I bought it used, so I suppose the people who had it before I did switched it out.
Why would the engine matter?
Old 05-21-2006, 01:51 AM   #4 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
your tach's gonna be way off if it's a V6
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 05-21-2006, 07:30 AM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Nope, it will simply show a higher "RED" limit. (6750RPM instead of 6000RPM)
Its the speedo that will be off if you use a V6 cluster. But you could simply swap out the speedo dial from your old unit and pop it into the new one. Problem solved.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-21-2006, 11:23 AM   #6 (permalink)
Tommy's Avatar
^that doesnt work.
The tach is way off, about 25%.
Different gearing on the speedo im pretty sure.
My garage
Old 05-22-2006, 06:45 PM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
mmmm..... misinformation....
Ok, please listen to me, as I have actually done this before...
Find a cluster from a Camry with the same motor as your car with a tach. Take that cluster and pull your speedo assembly from your current cluster and put it in the cluster with the tach. Put the hybrid cluster back in your car. BAM. Plug and play, correct speedo, correct odometer and nice looking stock tachometer.
-Charlie
Tachometer Install in 84 LE bigredtint Archived Corolla threads 0 04-21-2005 10:10 PM
1990 Celica GTS Drivtrain into a 1990 Tercel? denkelly Tercel, Paseo, Starlet, and Sera Forum 3 03-23-2005 06:29 AM
Quality of GT4 Celicas 1990 Tulkas Celica Forum 7 12-01-2003 04:52 AM
