Gen 2 AC fan won't work at low speeds - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2006, 02:03 PM   #1 (permalink)
Official TN member
View tracyf's Photo Gallery
2nd Generation Gen 2 AC fan won't work at low speeds
My brother serviced the AC on my wife's 1990 V6 Camry and after he got through the fan will now only work on the two highest speeds and not at all on the two lowest. It is not the end of the world and it does work at the high ones at least (and I did not want to complain when he had helped us out) but I wondered if any of you fine folks on here may have ran into a similar situation and the fix for it. Thanks for any advice!
www.tracystruesoaps.com
tracyf is offline   Reply With Quote
Old 05-24-2006, 02:12 PM   #2 (permalink)
View deekay140's Photo Gallery
needs a blower resistor.
deekay140 is offline   Reply With Quote
Old 05-24-2006, 02:14 PM   #3 (permalink)
Official TN member
2nd Generation
Thanks so much. I will check in the manual I downloaded and try to fix this last little thing up for her. Thanks again! Tracy
Old 05-24-2006, 02:21 PM   #4 (permalink)
np, its passenger side floor area, should be a single phillips head holding it in.
Old 05-24-2006, 09:28 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
http://www.toyotanation.com/forum/t62289.html check here for pics you might have to goto the dealer or make your own resistor pack.... i've pulled 2 resistor packs at the junk yard and they're both bad... it's a very common problem on the gen2 seems like everyone gets it sooner or later
Old 11-13-2007, 10:37 PM   #6 (permalink)
pusillanimous's Avatar
View pusillanimous's Photo Gallery
I've been driving around with only high speed on the blower for years now until I read these posts yesterday. I took out the resistor pack and soldered it together in two places but the wire is so stiff and flimsy and there's some rust on the base plate. Anyway, the blower worked on all speeds on the way to and from work. I need lessons in soldering though. My solder kept falling off the join spot. The solder is supposed to contain flux. Is there something you paint on to make the solder stick until it cools?
I called Radio Shack for the resistors in part # 90-903 but they say there's no such part. Same online.
Santa Monica, CA '91 Camry 4 DX
'03 Odyssey
Gloucester, MA
'01 Odyssey
'78 Coupe Deville
pusillanimous is offline   Reply With Quote
Old 11-14-2007, 12:28 AM   #7 (permalink)
Dave's
Gameroom cash: $120250
View Dave's's Photo Gallery
The wire becomes very hot. The solder melts. Replace it with something that will withstand the heat and current. (I've tried Radio Shack 5 watts without success.)
Dave's is offline   Reply With Quote
Old 11-14-2007, 01:16 AM   #8 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Well, they're not exactly cheap but: if I recall correctly, a new resistor array will run you around $65 at the dealer.
On the other hand, I've had very GOOD luck with scrap yard cars. I have 2 or 3 spares in the basement now.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-14-2007, 08:46 AM   #9 (permalink)
View wiccanferret's Photo Gallery
$65, IMO, is not a bad price for something that's not likely to break again for another 10+ years.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 11-14-2007, 03:15 PM   #10 (permalink)
Bullitprooph
True enough. Unless you have corrosion at the firewall, and moisture gets into that space where the resistors are. I've seen it on a few scrap yard cars over the years...
Old 11-15-2007, 07:18 PM   #11 (permalink)
I called around Los Angeles today for the gen 2 resistor pack and got a variety of prices. Santa Monica Toyota asks $78, Marina Del Rey Toy $65, and Miller Toyota, Culver City wants $49! These dealers are all within a few miles of each other. I won't buy yet since my solder-job is holding out but will go to Miller if it gives.
'03 Odyssey
Gloucester, MA
'01 Odyssey
'78 Coupe Deville
Old 11-15-2007, 07:31 PM   #12 (permalink)
Pochacco Owns Me
atobe's Avatar
interesting.. guess i'm going to have to buy one from culver city toyota then.
Old 11-15-2007, 11:24 PM   #13 (permalink)
It's Miller Toyota in Culver City, just off Venice, West of Robertson and the 10 freeway.
'03 Odyssey
Gloucester, MA
'01 Odyssey
'78 Coupe Deville
Old 11-29-2007, 06:27 PM   #14 (permalink)
toyota 4 runner truck resistor works on Camry
I posted this on another fan-speed thread but want to get the word out. Hope this isn't redundant:
"This auction is for a good fan resistor from a 1991 Truck. This will fit ALL Trucks from 1989 to 1995 using this style of fan resistor and 4Runners from 1990 to 1995."
I bought the above resistor for a 91 truck, thinking I could unsolder these coils and solder them to my '91 Camry DX resistor base. The base is a little different but my wires plug into the truck resistor and the truck one fit into the space on my Camry, though not precisely. The truck one works fine in my car without any new soldering or coil changing. Cost was $2.25 plus $4.00 shipping from E-bay.
'03 Odyssey
Gloucester, MA
'01 Odyssey
'78 Coupe Deville
Low fan switch doesn't work on 90 camry bpoppe4 1st & 2nd Generation (1983–1986 & 1987-1991) 19 10-04-2007 12:24 PM
AC low side service port? aaron7 MR2 Forum 3 08-27-2005 10:36 PM
Heater vent fan doesn't work. Help me! baartman Archived Corolla threads 7 01-24-2003 11:34 PM
Fan on intake hose work or not ???? AE110 General Discussion 2 07-20-2002 07:02 PM
