help with headers please. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2006, 09:47 PM   #1 (permalink)
Insanity makes more sense
View WVcamry3sfe's Photo Gallery
2nd Generation help with headers please.
I'm in the process of installing PaceSetter headers on my 3sfe engine. All is going alright, until I find that a mount for my engine/trans is in the way of the place made for the O2 Sensor... Its too long, so the mount is in the way of me plugging the silly O2 sensor into the headers. ARGH!!! Anyhow, I've thought about a way to solve my problem, first I'm thinking of trying to find a new oxygen sensor that is not as long as the old one is, so that i can squeeze it inbetween the hole and the mount. The second thing I'm thinking of doing is taking the header to a muffler shop and asking them to relocate the sensor hole on the headers themself.
These headers anyways, were not really designed for a 2nd gen camry... they were made for the 86-89 celica GT which runs the same engine (3sfe) which is why I got these particular headers, cause they were designed to fit my engine(and I couldn't find much in the way of performance headers for my car ). I'm just having a frustrating time with this O2 sensor... is there any way to eliminate the O2 sensor on the 2nd gen camry by chance...?
anyways, not all has been horrible with my exhaust upgrade so far. I've already got my HKS high power muffler in perfectly
WVcamry3sfe is offline   Reply With Quote
Old 08-12-2006, 11:17 PM   #2 (permalink)
Its A Camry Thing... ok?
View SymtecX2003's Photo Gallery
2nd Generation
it seems that you might just be able to get it relocated just make sure that they dont leave any leaks where the whole was..... and btw where did you find a pacesetter for a 3sfe all i could find was 3sge.....
http://i11.photobucket.com/albums/a1...X/100_3144.jpg
It may be a camry but its mine....
SymtecX2003 is offline   Reply With Quote
Old 08-12-2006, 11:43 PM   #3 (permalink)
http://www.sfxperformance.com/parts/PAC701155.htm is what I got... PaceSetter headers for the Celica GTS. It bolts up fine to the engine, but the down pipe is a bit tricky... and then of course the durn O2 sensor (my current issue). At anyrate, SFX performance has those headers, I've seen them on other web venders as well. But SFX was the first one that I ran into. Might be able to shop around a little bit to get a better price, but anyhow. I'll get pics of it up once I figure it all out if you're interested. also note about the picture on the website is misleading... its a generic pic they have for most al pacesetter headers. its not the actual header that is pictured there.
Old 08-13-2006, 08:47 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You have some options:
1. Cut off the O2 sensor mount and have it welded on somewhere else. The existing hole will need to be patched.
2. Make a plate to block off the hole for the O2 sensor. Have a O2 sensor bung welded on for a screw in type O2 sensor.
Buy a universal single wire O2 sensor (screw in type). You'll have to splice the wiring together.
No, you can't eliminate the O2 sensor.
"Skoolin' the unlearned!"
Old 08-13-2006, 09:59 PM   #5 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
Why would you want to terminate the O2 sensor? If anything you would want a better (wideband) O2 sensor ...
camryfour is offline   Reply With Quote
Old 08-13-2006, 11:41 PM   #6 (permalink)
View boi_si's Photo Gallery
let us know...
i was thinking of using a celica header as well...
-03 Matrix XR
-90 Celica turbo Alltrac
boi_si is offline   Reply With Quote
Old 08-13-2006, 11:45 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
is the 02 in a primary pipe or the collector?
Old 08-14-2006, 12:11 AM   #8 (permalink)
ApexiCamry
View DiscoPotato's Photo Gallery
Aren't there 2 sensors on the 3s-fe exhaust manifold? Does the pacesetter header have two holes for them?
DiscoPotato is offline   Reply With Quote
Old 08-14-2006, 02:59 AM   #9 (permalink)
its at the end where all four pipes meet up, so yeah its in the collector where the hole is. anyhow... if it was further up I wouldn't be having this problem :-D
well...tomorrow, err today for me actuall... 4AM here, I'm takin my headers to someone who can weld and I'm just going to describe to them how I want to change it... I've already engineered a solution to my delima I guess... hope it all goes according to plan. If it all works out, then tuesday I'll be out on the road seeing how the car is with this thing in. I'm honestly not expecting all that much, but we'll see...
Old 08-14-2006, 06:11 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
Some have 1 (pre-cat) and some have 2 (pre-cat and post cat).
Old 08-14-2006, 06:21 PM   #11 (permalink)
View 32oz.'s Photo Gallery
2nd Generation
got pix of the exhaust? im curious what that would look like
1991 4cyl 5speed 20% tint stock as a rock w/203,xxx and counting
32oz. is offline   Reply With Quote
Old 08-14-2006, 08:24 PM   #12 (permalink)
post pics when you get time i want to see to help myself decide :d
Old 08-14-2006, 11:26 PM   #13 (permalink)
yes.. my 89 5spd has 2 o2 sensors... my parents 88 auto has 1... kinda weird...
-03 Matrix XR
Old 08-15-2006, 08:48 PM   #14 (permalink)
I'm sooooooo close to having this project finished. Today I got almost everything workin, but... one of my exhaust manifold studs stripped the inside threads of the engine head! !!! I now have to take my car and get it towed to a machine shop in order for them to repair this so that i can put a new stud into the engine head... Otherwise the headers will leak exhaust all the time... But I'm gettin' so d*mn close!
Anways, I've got my o2 sensor in. I moved the hole for it to the down pipe. I will have pics up sometime very soon I hope... although I'm terribly busy, workin on this and gettin ready to go back to school tho...
Old 08-17-2006, 12:05 AM   #15 (permalink)
hey all! I've got everything in and working now... I'm glad that one's over! but anyhow, now my exhaust is really.... loud :-\ I need to find a cat converter that I can put in further down the pipe without spending too much cash, since its running low... fixing that stripped engine head cost me 50 dollars plus a ten here and there for other things. Any ideas on a cheap high flow cat that won't take too much time and effort to install?
Installing my Ripp Headers Camrymatic Camry & Solara Lounge 12 04-14-2007 11:40 PM
Headers for 4A-F(E) & 7AFE thespud Archived Corolla threads 0 06-07-2006 12:30 AM
Gen2 headers Ripa_TT 1st & 2nd Generation (1983–1986 & 1987-1991) 4 08-24-2004 12:49 PM
