Differential lube - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2006, 09:16 AM   #1 (permalink)
dacecil's Avatar
View dacecil's Photo Gallery
Differential lube
While getting my engine ready to install, I noticed oil leaking out of axle holes in the differential. It certainly appears to be heavy 90w gear oil. The book calls for Dexron II in the diff.
Can anybody tell me if the two are interchangeable or did the last owner put the wrong stuff in or what. Should I drain the 90w or just refill it or should I replace it with Dexron II?
Thanks
Dale
dacecil is offline   Reply With Quote
Old 09-09-2006, 09:54 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
90W gear oil is not the same as Dexron II ATF. Gear oil is a lot thicker.
I would drain it as best you can, then refill with Dexron II or III ATF.
"Skoolin' the unlearned!"
Old 09-09-2006, 05:10 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
dexron 3
Old 09-09-2006, 08:24 PM   #4 (permalink)
View toyomoho's Photo Gallery
For the differential, Toyota seems to call out whatever the transmission uses. If a manual trans this is 75-90W. If an automatic this is whatever the trans uses, such as Dexron.
Front Differential Cerritos 1st Generation (1995-1999) 13 09-18-2006 12:12 AM
Locker or limited slip Gonefishin 2nd Generation (2005+) 30 06-20-2006 09:28 AM
Jiffy Lube stevenh563 Off Topic 21 06-15-2006 11:50 PM
93 corolla differential problem atomicDog Archived Corolla threads 12 12-29-2005 11:37 PM
94 V6 Camry-Where is the differential fill hole? Nowhere Man 3rd & 4th Generation (1992–1996 & 1997–2001) 9 08-24-2005 03:45 PM
