repairing a rear window demister - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2006, 06:43 AM   #1 (permalink)
View bigbikes2003's Photo Gallery
2nd Generation repairing a rear window demister
Hi guys.
My daughter has a 91 camery and the rear window demister isn't working. The problem is that on one side where the wire is supposed to be connected to, the actual connector on the windscreen is missing.
Now is there any way that I can connect the wire to the demister. Any idea's guys.
Iv'e tried asking at all the local windscreen fitters but they recon I have to buy a new rear windscreen...( yea right ) there has to be a way to connect this power wire back into place somehow.
Thanks guys.
Cheers
bigbikes2003 is offline   Reply With Quote
Old 09-11-2006, 12:46 PM   #2 (permalink)
View michoujordan76's Photo Gallery
Hi, I had the same problem with mine. The tab that is soldered to the defroster grid had come off. I bought a glue-like product from the autoparts store. Now it works well. Maybe you can get a new tab from a salvage yard and buy this stuff to attach it :http://www.frostfighter.com/ff_pdt_2000.htm
Good luck!
michoujordan76 is offline   Reply With Quote
Old 09-14-2006, 05:12 PM   #3 (permalink)
1987 Celica GTS
Noobified's Avatar
View Noobified's Photo Gallery
The defroster works by running current through the wire grid built into the glass. Yours seems to have broke off, so I suggest getting a similar clip, and soldering it back on. But, as long as you get it to make a connction again, it will work. Good luck
Noobified is offline   Reply With Quote
Old 09-14-2006, 08:06 PM   #4 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I;ve seen those break off before, and you may have (if you're lucky) a bit of the original solder from the tab still in place. Like Noobified said, it will work again if you can solder the wire back to it. I'd use the lowest wattage (heat) soldering iron you can find though, as I'm sure it's a risky job to solder on a window.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
01 Sequoia rear window problem MATHU1789 Sequoia Forum 2 11-21-2006 12:21 AM
Rear Window wiper '92 92_Gen3_5SFE_LE 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-12-2005 09:08 PM
Rear window glass shattered in theft attempt? Cost $850. dmarcoot Scion Forum 3 08-20-2004 05:02 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
