1990 Camry Too Fast Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2006, 03:57 PM   #1 (permalink)
View 1122union's Photo Gallery
My 1990 4 cyl. (automatic) Camry's idle started running too fast all of a sudden. It almost seems like I have a vacuum leak, but the car runs fine with no misses etc. I sprayed starting fluid around the hoses looking for a leakwith no success. My Haynes tells how to adjust the idle on cars up to 1987 (after that nothing).
What should I look for?
Thanks,
RK
1122union is offline   Reply With Quote
Old 09-15-2006, 06:33 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Check idle speed control valve, if it does not help, find out that there is the power steering pump air control valve is not stuck open.
Doctor J is offline   Reply With Quote
Old 09-15-2006, 09:03 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
There is an adjustment screw ontop of the throttle body.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 09-15-2006, 09:15 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
i bet its just full of dirt
Old 09-16-2006, 01:46 PM   #5 (permalink)
Too fast idle
I cleaned the throttle body and screwed in the adjustment screw. The idle slowed down but I still think I have a vac leak somewhere and the screw is just compensating for the leak. If the engine noise iwasn't so high I probably could hear it. Maybe I can find a vacuum system diagram somewhere.
Thanks again,
RK
Old 09-16-2006, 02:31 PM   #6 (permalink)
NYR
View IvanHoe's Photo Gallery
Spray starter fluid on the vacuum hoses. If there is a leak, the idle will get really high for the moment the spray is applied to the area.
.....old school trick
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 09-17-2006, 03:10 AM   #7 (permalink)
View toyomoho's Photo Gallery
Or try using a small propane torch, valve on but no flame. The propane will also get into any vacuum leak and effect the idle.
94 Camry dying at idle 2 8 3rd & 4th Generation (1992–1996 & 1997–2001) 12 08-07-2006 04:03 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
Idle Speed Problem 1998 Camry 4 Cylinder/Auto cdlubbe 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-26-2005 08:24 AM
1990 AllTrac Camry DriveTrain dejacky 1st & 2nd Generation (1983–1986 & 1987-1991) 15 06-07-2004 01:41 AM
