Need Help! 88 Camry Brake and Tail lights out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2006, 06:45 PM   #1 (permalink)
Gen 2 Pimp
phat91camryLE's Avatar
View phat91camryLE's Photo Gallery
2nd Generation Need Help! 88 Camry Brake and Tail lights out
Hey guys,
My room mate's 88 Camry has an issue. Recently the tail lights and brake light went out. He said he checked the fuses, relays, and changed the bulbs, but it wasn't any of those. He wants to avoid taking it in? Anyone have any suggestions on what he should do?
Thanks in advance,
Matt
4 cyl 1991 Camry LE ... if you own a 2nd Gen Camry talk to me about the modifications you have made or wish to make... lets help eachother out
phat91camryLE is offline   Reply With Quote
Old 09-21-2006, 06:57 PM   #2 (permalink)
View PeonHonda's Photo Gallery
So youre saying that his parking lights and all three brake lights are out?
ok now did he check that there was voltage at the fuses or did he just check to see if they werent blown?
PeonHonda is offline   Reply With Quote
Old 09-21-2006, 07:05 PM   #3 (permalink)
View toyomoho's Photo Gallery
The brake and taillights have separate power circuits and fuses. Check for power at the fuse as PeonHonda states. Could be two different problems such as a bad brake switch on the brake pedal. Check for bad common ground wires in the tail and brake light wiring.
Old 09-21-2006, 09:58 PM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
You may also want to check the wiring harness where it runs along the floor of the trunk; if your roommate threw something in the trunk it could have split the wires...happened to me.
The wires run from the rear deck, along the left (driver's) side floor, and up the frame (by the power antenna harness). If the car's rusty, water seepage in the trunk will also cause troubles. Good luck!
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 09-22-2006, 01:40 PM   #5 (permalink)
Gameroom cash: $302555
TBayToyotaBoy has the right idea, but I think he has the wrong location for the loom of wires in the trunk. The loom of wires is located by the driver's side trunk hinge. It's really up high in the trunk. Those wires have a tendancy to fray and break from all the flexing they are exposed to when the trunk lid is opened or closed. Open up that loom of wires and looked for broken or frayed wires. Repair them as necessary. This is a common problem area on all generation Camrys.
Mike
Mike Gerber is online now   Reply With Quote
Old 09-22-2006, 05:23 PM   #6 (permalink)
Its A Camry Thing... ok?
View SymtecX2003's Photo Gallery
2nd Generation
if all his lights for his brakes and all are out its one thing your tail lamp relay box has went out...its something that has happend to all my gen2 camrys.... it will be located in the trunk behind the carpet and such on the driver side.. its a yellow box just remove it and open it and see if there is any burnt connections or such... if so you will have to jumper the connections for your brake lights or buy a new box ($80) online :/.... pics later if you need on where to jumper and such to make your lights work
http://i11.photobucket.com/albums/a1...X/100_3144.jpg
It may be a camry but its mine....
SymtecX2003 is offline   Reply With Quote
Old 09-22-2006, 07:39 PM   #7 (permalink)
Gen 2 Pimp
turns out it was the tail light relay box. My room mate could not wait and now he is paying 250 bucks to get a new one installed at the dealership...I told him to buy it online but nooooooooo... thanks for the great responses guys...now only if my room mate listened....
Later,
Matt
Old 09-23-2006, 04:41 PM   #8 (permalink)
NYR
View IvanHoe's Photo Gallery
Later,
Matt
It seems like your roomate likes to flush $ down the toilet. It's a 2 second job to swap out the relay.....a definate DIY repair!
And like the other member said, you can find it for $80 online
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 09-23-2006, 09:02 PM   #9 (permalink)
Later,
Matt
HEY GUYS YOU CAN RELAY IT WITH STIFF WIRE FOR FREE..... I DID AND I CAN SHOW YOU IF YOU WANT :P
Old 09-24-2006, 11:18 AM   #10 (permalink)
NYR
Please do.....just in case I have this problem in the future......oh and your capslock button is on
Old 09-24-2006, 02:44 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
What happens is the traces on the circuit board burn up or break.
Remove that box, open it up, and pull the circuit board out. Patch up any broken / burnt traces or jumper around them with wire.
A DMM (digital multi meter) will come in handy for checking continuity.
"Skoolin' the unlearned!"
Old 09-24-2006, 07:44 PM   #12 (permalink)
NYR
Right, I did that to my gauge cluster on my former former former ride(91' Olds Sillouette)
Old 09-24-2006, 09:48 PM   #13 (permalink)
sorry bout the caps... and will add an image when photobucket stops being gay :/
Old 09-29-2006, 07:45 AM   #14 (permalink)
Bullitprooph
Kinda wierd that it was the relay box...does your Camry have an idiot light on the dash for "burnt-out light"? When my relay went, I got an intermittent warning light which told me I had a problem...I thought all Camrys had this nifty little feature?
Brake lights won't work when headlights are on... Psykosoma Yaris, Vitz and Echo Forum 11 01-19-2008 03:38 PM
Tail light help, 84 camry Paul B 1st & 2nd Generation (1983–1986 & 1987-1991) 1 06-14-2005 11:52 PM
Tail Lights Not Working? djtech Archived Corolla threads 0 05-19-2005 09:23 AM
No Brake Lights!! randycoutour Camry & Solara Lounge 10 11-27-2004 11:05 PM
tail lights out, problem not the bulbs or the fuse jr_certs Camry & Solara Lounge 7 11-05-2002 12:11 AM
