manifolds - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2006, 09:53 PM   #1 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
2nd Generation manifolds
Hey all, I need an idea, I am getting ready to put a 2vzfe into my car and am wondering how to get rid of the retarded way the front bank dumps the exhaust over the bell and into the back bank manifold, I want a set that exits downwards so i can just run the front bank underneath and out the back along side the pipe from the rear bank so i can have a true dual setup? Will a 3vzfe set fit?
Old 09-24-2006, 02:43 AM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
3VZFE won't fit...(tried em ) So custom is the only other answer. Its pretty easy to get flanges made up and start bending some pipe for it to fit to whatever you want.
If you need any pics of my extractors, which exit downwards, let me know.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 09-24-2006, 10:31 AM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
lemmesee?
Old 09-24-2006, 07:25 PM   #4 (permalink)
VeeZed
Old 09-24-2006, 08:39 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
sheesh guy, you make those up? what keeps the 3vz manifolds from fitting, is it the head or do they hit something?
Old 09-24-2006, 11:59 PM   #6 (permalink)
VeeZed
Yep they are custom made.
The head/flange is what stops them from working. There may also be issues with they way they run, because the Gen 3 has a completely different undercarriage to the Gen 2...so crossmembers and steering components may get in the way. But they certainly don't bolt up, so that would be the first thing to figure out (maybe using an adaptor plate or something).
Old 11-08-2006, 01:43 AM   #7 (permalink)
View Tater250's Photo Gallery
Originally Posted by JetspeedCamry
I admire your dedication and attention to detail, cool!! Anyhow do you have any more pictures of the undercarrige? I have a 91 Lexus (2VZFE) and im want to do a similar mod. I was particularly concerned about about how you routed the front pipe below, did you remove the center support or do camrys lack this? Thanks
Tater250 is offline   Reply With Quote
Old 11-08-2006, 03:58 AM   #8 (permalink)
VeeZed
Hey there.. Thankyou!
Everything is original in terms of mounts and supports. There is a centre mount on the N-S member which wasn't effected. There is a gap small enough to fit the pipe straight under the sump and over the top of that E-W member. And then as you can see, the Y-pipe is just after that.
It's my understanding that the ES250 shares the same undercarriage/chassis as the Camry, so all should be the same if you can follow what i've done here.
Found some more pics:
Cheers
Old 11-08-2006, 07:24 PM   #9 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Man, that is an awesome job. It's nice how the front pipe just sneaks over that crossmember, and nice how it fits snugly next to the oil pan...I probably wouldn't have believed it without the pics. Kudos on a custom job done right...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-10-2006, 07:08 AM   #10 (permalink)
View MindQuicken's Photo Gallery
Any advice on how best to turbocharge the 2VZ-FE? The exhaust system is weird. Can I simply just tap the front exhaust valves? I got 80k miles on it and it's still running like new. The auto tranny can't handle much more than 300 HP, so my goal is somewhere close to that. Installing the E153 tranny is too expensive for me. I heard this engine has got some strong stock internals.
MindQuicken is offline   Reply With Quote
O2 sensors & manifolds ognc 1st Generation (2000–2006) 3 02-12-2006 12:15 PM
Some good news for tubular manifolds (MR2BAD) JekylandHyde MR2 Forum 5 03-14-2005 11:52 AM
3SGTE Manifolds & Turbos luisitol Camry & Solara Lounge 7 09-05-2003 09:14 PM
