Heater Fan switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2006, 12:26 PM   #1 (permalink)
View isktarum's Photo Gallery
Gen1 Heater Fan switch
Hey guys, I'm new here, and I don't see many posts for Gen1 Camry's. I guess there aren't too many left running on the streets.
Anyway, I've got an '86 and the 5-way switch to adjust the fan speed for the heater inside seems to only work after the 4th position. So in the winter I can only get the fan to run in pos 4 and 5.
Any ideas why i dont get the fan running when the switch is in one of the lower positions?
Thanks.
M
isktarum is offline   Reply With Quote
Old 09-25-2006, 01:48 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Check the blower motor resistors.
More info and pics:
http://toyotanation.com/forum/t62289.html
"Skoolin' the unlearned!"
Old 09-25-2006, 01:48 PM   #3 (permalink)
NYR
View IvanHoe's Photo Gallery
Thanks.
M
It's a common issue. Do a search and there's info on the subject. I know personally cause I inquired about the same thing a while back, but I dont remember the specifics.
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 09-25-2006, 05:08 PM   #4 (permalink)
Thanks for the links guys, and sorry for my ignorance. I should've done a search on this forum first. Anyway, I pulled the resistor pack out and indeed two of the three coils have broken.
I can't seem to solder them back together so I may run to the salvage yard and find an used one intact. Does anyone know if they changed the resistance in the packs between Gen1 and Gen2?
ie: I have an '86, could i use the resistor pack from a '90 camry?
Thanks.
M
Old 09-25-2006, 07:05 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
The resistance and pin out may have changed between gen 1 and gen 2. I can't say for sure without seeing schematics for both.
If you find a good one from a gen 2, you can probably use the resistors. Just unsolder them and use them to replace your broken ones.
Old 09-25-2006, 08:43 PM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
i know the pins are different between the gen2s... if you have the push buttons it has a 6pin connector while if you have the regular levers for air it's 4 pin connector.
Old 09-25-2006, 08:43 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
slider type.. not lever they're all levers
1987 pickup heater fan resistor location? firestorm1 Pre-88 Toyota Pickup/Hilux 3 06-03-2006 03:27 PM
How Make The Dummy Switches Work For Real - And Cheap Too... Hughes500Pilot 2nd Generation (2005+) 7 02-03-2006 10:42 PM
This should scare the shit out of tailgaters 87Camry5Speed General Discussion 54 02-03-2006 09:41 PM
