1991 V6 Crank Pulley "Wobbly" at Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2006, 03:09 PM   #1 (permalink)
View Variety=Spice's Photo Gallery
2nd Generation 1991 V6 Crank Pulley "Wobbly" at Idle
I picked up a new project yesterday, a 1991 Camry Station Wagon V6. It has a myriad of problems that need attention, but one of the less straight forward ones is the wobbly crank pulley (the pulley that drives the accessory/serpentine belt.)
At idle I can see the pulley wobbling; the pulleys on the alternator and water pump, etc are not. When I increase the RPMs to 1500 or 2000 the pulley seems to stabilize and appears to run smoothly.
I'd think that if the pulley had been bent during a timing belt change then the problem would not go away at higher RPMs.
Any ideas?
Variety=Spice is offline   Reply With Quote
Old 09-26-2006, 06:48 PM   #2 (permalink)
View toyomoho's Photo Gallery
The pulley may be a two-piece design. Someone may have damaged it when they pulled it off at the last timing belt change. This can happened if a clamp type puller is used instead of a bolt on. Best find a replacement, try a junkyard. It could just look like the problem goes away at higher RPM, but is still there.
Old 10-14-2006, 09:35 PM   #3 (permalink)
View marc780's Photo Gallery
You need to change the pulley. The crankshaft is massively strong and it will break before it will bend! So it's a safe bet the problem is the pulley. Easy to pull one at a junkyard.
Help!. Changing Timing Belt But Cant Get Dam crank pulley and Crank Pully Bolt Off tousi Camry & Solara Lounge 21 04-26-2006 09:58 PM
