Highway-speed Vibration. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2006, 12:33 AM   #1 (permalink)
View 25psi's Photo Gallery
I've had this problem for a little while but it's never really bothered me as I rarely drive the car on the highway but would like to figure it out for peace of mind.
Car is a 91' 3sfe auto. I've recently gotten an alignment,new tires, and CV's but it still does it. Seems to start around 70, worst at 75 and gets better as speed increases. I can mainly feel it through the steering wheel and gas pedal, and a little bit through the body.
Any ideas?
-Jim
91' Camry DX 3S-FE
25psi is offline   Reply With Quote
Old 10-01-2006, 12:49 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
take it back to where you got the tires and have them find it
Old 10-01-2006, 12:51 AM   #3 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
It's tire balance. Get them rebalanced again. The place where you got your new tires installed should replace them again for free.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 10-01-2006, 12:53 AM   #4 (permalink)
I probably will but it did this with the old tires too.
-Jim
91' Camry DX 3S-FE
Old 10-01-2006, 02:27 AM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
worn bushings and such
Old 10-04-2006, 09:39 PM   #6 (permalink)
View marc780's Photo Gallery
wheels may be bent (steel type), tires wobbly tread (spin it and look at them, seldom do they spin perfectly with no up and down due to tread and tire irregularities). And likethe other fellow said, balance, they may have done a poor job of it when you changed tires.
Old 10-04-2006, 10:05 PM   #7 (permalink)
I'm pretty sure it's not the tires, they're brand new and it did the same thing with the old ones. I have aftermarket 17" Aluminum wheels. Could be the balance I guess but that means two different shops both screwed it up.
-Jim
91' Camry DX 3S-FE
Old 10-04-2006, 10:40 PM   #8 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
are they offset real far or is the car dropped?
Old 10-08-2006, 03:05 PM   #9 (permalink)
the gen 2
blkdmnrcing's Avatar
View blkdmnrcing's Photo Gallery
i know its a long shot, but i had somewhat of the sam concern, raised my car on the lift at work, noticed that both axles had extreme play in them. (i actually broke one a week later). i replaced both axles and havent had a vibration since.
89 Camry I4 5-Speed - JDM Head, Turbo'd! Now needs Exhaust and Tune!!
93 Paseo I4 Automatic - Daily Driver
look out, ed wants to drop kick spiderman!!
blkdmnrcing is offline   Reply With Quote
Old 10-09-2006, 01:14 PM   #10 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Go through the suspension. Check the top mounts of the struts. Look at the two axles. I believe the passenger side axle has a bearing supporting it. Make sure the two bolts are torqued correctly. The tires/wheels are still suspicious. I think that there are places that will balance them on the car. You might check into that if all else fails.
Kep
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
car died on highway chadi Archived Corolla threads 14 09-13-2005 10:42 AM
Wind noise at highway speed Pimpin' Smurf Yaris, Vitz and Echo Forum 3 09-28-2004 10:16 AM
Strange Idle Speed terrynham Camry & Solara Lounge 4 03-06-2004 12:52 AM
