Flooded Engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2006, 12:58 PM   #1 (permalink)
View jcb62988's Photo Gallery
Flooded Engine
I'm getting an excess amount of fuel in my engine. The spark plugs come out wet and stinking like gas, and when i took off the intake hose and look through the throttle body into the intake manifold i can see gas sitting in it. I don't know how gas is getting up there, since the injectors are down below, and all i can think of is that the cold start injector is leaking a lot of gas, or that the ecu is bad. I checked the resistance on the cold start injector, and that was fine, but does anybody know how to do further testing on the cold start injector?
jcb62988 is offline   Reply With Quote
Old 10-05-2006, 01:23 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
To do quick leakage test:
  • remove 2 bolts that attaching cold start injector to the intake plenum, leave a fuel line conneted but unplug electrical connector
  • insert the injector tip into the can
  • short FP and B+ terminals in diag. box with jumper
  • turn ign. on for 3 seconds, do not crank the engine
  • turn ign. off , remove jumper
  • check the can/ injector tip. No fuel must be present/ leaking
  • reinstall injector
Doctor J is offline   Reply With Quote
Old 10-09-2006, 01:16 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Have you exonerated the cold start injector timing switch as well as the injector itself?
Kep
Old 10-09-2006, 02:02 PM   #4 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
I've had the same issue with mine, and yes, it was a leaking cold start injector. I got it to stop leaking, then unplugged it.
The leak test I did was very similar to what Doc posted, but my instructions said to observe the injector with the FP & B+ terminals jumped, which I did. I don't think I did anything with the ignition switch though. Spec is 1 drop per minute leakage, mine was 1 drop every 3-4 seconds.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
'98 Corolla engine noise earthmover Archived Corolla threads 5 10-28-2009 09:16 PM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Engine number four, HELP heroteh Hardcore Tech and Competition 2 05-07-2005 05:07 PM
