Vibrations... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2006, 02:36 PM   #1 (permalink)
View michoujordan76's Photo Gallery
2nd Generation Vibrations...
Hi everyone,
My 91 camry has been jerking when I put it into gear (automatic) and it tends to vibrate at speeds just above idle.
Do you think it's motor/transmission mounts? Are they expensive to replace?
Thanks!
michoujordan76 is offline   Reply With Quote
Old 10-15-2006, 11:09 AM   #2 (permalink)
Any ideas, anyone?
Old 10-15-2006, 12:42 PM   #3 (permalink)
Toyota Hemi
camryfour's Avatar
View camryfour's Photo Gallery
Motor mounts do make it kick when you put it into gear. It also will make it kick when you shift gears. To check your motor mounts, turn car on and leave it in park. Open your hood, rev your engine with your hand by the throttle linkage. If you see the engine move a lot more than it should then its most likely your motor mounts. By vibrate, do you mean shudder? If it shudders and vibrates bad when you shift gears, it could be a transmission problem.
camryfour is offline   Reply With Quote
Old 10-15-2006, 02:23 PM   #4 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Engine vibration on 1500 rpm that is transmitted trough the steering column could be due to defective harmonic balancer (crank pulley) or loose torque converter to flexplate bolts.
Doctor J is offline   Reply With Quote
Idling Vibrations frankl 1st Generation (2003-2008) 13 09-07-2006 12:41 AM
Vibrations jkjk15 Archived Corolla threads 0 08-29-2006 11:38 PM
Serious Vibrations Caused by Cressupra Cressida Forum 2 06-05-2006 10:56 AM
Gas Pedal Vibrations terrynham Camry & Solara Lounge 3 01-29-2004 10:04 PM
MK1 steering vibrations 86na MR2 Forum 7 11-16-2002 09:17 PM
