90 Camry v6 engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2006, 11:22 AM   #1 (permalink)
View dsulu's Photo Gallery
USA 90 Camry v6 engine
I have had this happened to my car a long while back, while I was driving the car, I started hearing some tapping sound coming from the engine. and it got louder and louder until a pop was heard, the engine died.
The engine had been leaking oil due to seal/gasket failure, so it is no surprising that the engine eventually failed.
So where is most like area that got damaged, the engine head (valve, cam), cylinders or the piston?
I am interested in rebuilding the engine if all possible.
Any comment and suggestion is greatly appreciated!
dsulu is offline   Reply With Quote
Old 10-12-2006, 02:48 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Sounds like the engine threw a rod. Are there any holes in the block or oil pan?
At this point theres not much you can do, other then start taking the engine apart. I'd start by removing the oil pan and look for chunks of metal.
"Skoolin' the unlearned!"
Old 10-12-2006, 02:56 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Bent a rod, or snapped one. The offending cylinder wall, piston + rod + associated connecting hardware, crankshaft & bearing surfaces.
Drop the oil pan & take a look. If it popped, go buy a used one with a warrantee that it'll run for afew months & put some new gaskets in it to make sure it's OK & wont leak.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 10-12-2006, 04:57 PM   #4 (permalink)
Thanks guys!!!!!!!!!!!
Old 11-25-2006, 11:45 AM   #5 (permalink)
View marc780's Photo Gallery
I'd go for a used Japan engine -
Old 11-25-2006, 11:25 PM   #6 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Unfortunately you can only get the 1vzfe from Japan not the 2vzfe. The 1vzfe has a smaller displacement than the 2vzfe.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
Anyone swap an jdm v6 engine in a 90 Camry V6? cheezthis 1st & 2nd Generation (1983–1986 & 1987-1991) 19 10-06-2004 10:05 AM
