relay Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2006, 04:33 PM   #1 (permalink)
View kerone44's Photo Gallery
Unhappy relay Help
Hey i have a 1991 Toyota Camry (4 door). My power windows are not working. i have recently replaces the master window switch and checked the wire harness for any short circuits. Is there any way to test a relay? (using a voltage meter or something like dat ?) or another way?
kerone44 is offline   Reply With Quote
Old 10-16-2006, 06:33 PM   #2 (permalink)
View toyomoho's Photo Gallery
Do all the power window switches not work? The passenger windows have two sources of power. One directly from the power main relay, the other is through the driver’s console. Check to see if there is power at the Blue wire, this is the power from the main relay. Make sure the ign key is rotated to ACC.
Old 10-16-2006, 09:30 PM   #3 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
I've also found that the drivers side door wiring harness, if the wires have broken where they flex, will cause your windows not to work at all. It is similar to using the lockout button on the main switch. I have used a door harness from a parts car to test this. I just plug it in to the main harness behind the kick panel and test with the main switch.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
96 Camry Wiper Relay DD 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-02-2008 02:50 PM
please help gal with radiator fan relay switch question atoyotchick Tercel, Paseo, Starlet, and Sera Forum 3 11-09-2005 12:13 AM
Need Help With a Relay Problem Dr Tweak Hardcore Tech and Competition 1 02-15-2005 03:43 AM
Relationship of C/OPN relay and EFI/F-HTR relay Dr Tweak Hardcore Tech and Competition 0 02-03-2005 03:08 AM
Temp gauge relay [gen2] Zfreeman 1st & 2nd Generation (1983–1986 & 1987-1991) 9 08-21-2004 07:00 PM
