Need a quick answer please!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2006, 08:25 PM   #1 (permalink)
View diverjeff's Photo Gallery
Hey all:
"Scooter" the '87 Camry has been running rough. Changing the plug wires, rotor, distributor cap. After removing the cap, the gasket or what the dealer called "packing" was in pretty bad shape, so I will order one from dealer tomorrow. The dust shield was in 3 pieces so depending on responses, I may or may not order one.
Is it necessary to have the dust shield? Only thing I can see it covers is the coil.
Thank you for the suggestions,
DJ
My wife said if I don't quit buying vehicles that need work she was going to leave me..... I'm sure gonna miss that woman.
diverjeff is offline   Reply With Quote
Old 10-19-2006, 12:14 AM   #2 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
Your coil may be affected by moisture. Although I'm not sure that is what is causing your car to run rough....
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 10-19-2006, 09:51 AM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Um, even if you haven't seen the "check engine" light come on (assuming the bulb isn't burnt) I would still run a diagnostic. If you get a trouble code, I wouldn't be surprised if your O2 sensor is shot...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 10-21-2006, 05:09 AM   #4 (permalink)
Follow-up...
Hey all:
Success!! Changed plugs, rotor, plug wires. Plug boot #4 had a place on it that appeared to be leaking spark. There was a round bluish area with a white center right where the boot attaches to the plug. Also, it wasn't the dust guard that broke but a plastic shield. The Yota dealer said the guard is a safety issue to prevent someone brushing the coil and getting zapped.
I appreciate the ideas and help!
Respectfully,
DJ
Need a quick answer about fuel and 3vz-fe ag6286 Camry & Solara Lounge 4 07-07-2005 12:03 PM
Bringing the quick life to an 82 trecel. need answer??? wicked t Tercel, Paseo, Starlet, and Sera Forum 2 05-11-2005 10:24 AM
need an answer quick in order to get rims off ebay illusive562 Camry & Solara Lounge 2 02-16-2005 05:56 PM
Need quick answer to wiring ? spyfish007 Camry & Solara Lounge 2 05-11-2004 05:33 PM
Need a quick answer..admins, you can dump this thread right after it's been answered Redline Camry & Solara Lounge 4 05-08-2004 03:37 PM
