Originally Posted by DiscoPotato
What kind of relay is that 88le? Does 12VDC/30A SPST Automotive Relay work?
That'll work just fine.
The one in my drawing is a SPDT (single pole double throw). Only difference is that it has an extra terminal (87a), but its not used.
87a is NC (normally closed) to 30. When the coil in the relay (85 and 86) is energized, 87a to 30 is open.
87 is NO (normally open) to 30. When the relay is energized, 87 to 30 is closed.
After the key is on ignition, the whole power goes out.
Sounds like a short somewhere or something is not getting power.
Have you checked the battery?
