Is the a heater core problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2006, 01:58 PM   #1 (permalink)
View edwardr's Photo Gallery
Hi forum,
This is my first post. I need your help to diagnose a problem. My car is a 1990, 3SFE.
When I turn on the heater, my windows fog up. No amount of heat will get rid of it. When I turn on the A/C with the temp. slider still set to heat, the fog clears up.
I suspect that extra humidity is coming from a leak in the heater core but I haven't found any dampness anywhere to confirm this.
Has anyone had similar symptoms and found the cause of the problem? I don't want to tear into the dash to replace the heater core unless I'm pretty sure that's the problem.
I appreciate any and all advice.
edwardr is offline   Reply With Quote
Old 10-21-2006, 06:34 PM   #2 (permalink)
View toyomoho's Photo Gallery
Is this a new problem, did the heater ever defog the windows in the past? Is the heater control on outside air (best) or recycle? When the heater control is on defog, does hot air actually come out of the upper dash vents to defog the windows?
The A/C defogs the windows a lot faster, this is normal. Running the A/C to defog windows is fine and will not hurt anything.
Before you take the car apart, start keeping close tabs on the coolant level. If staying the same, you do not have a leak. If a leak, you may also smell coolant in the car.
Old 10-21-2006, 08:27 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
does it smell like anti freeze?
Old 10-22-2006, 11:59 AM   #4 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
get a coolant system pressure test done.that will let you know if there is an issue with your heater core or not. but your symptoms sound similar to what i had when mine went.
Huy
1989 BEAMS 3S-GE SV21 Camry
da_horse is offline   Reply With Quote
Old 10-23-2006, 08:06 AM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
At the time when you turn the heater on is air mixer is on FRESH or RECIRC position?
High humidity inside the car such from the damp carpet or plugged up heater/a/c unit drain tube are addding extra moisture to the inside air.
Doctor J is offline   Reply With Quote
91 4 cyl heater core repalcement ufatbastehd 1st & 2nd Generation (1983–1986 & 1987-1991) 2 08-01-2006 06:01 AM
Mice in heater core. copernicus 89-95 Toyota Pickup/Hilux 5 05-05-2006 11:11 PM
Problem with heater core Ferrat Camry & Solara Lounge 0 04-11-2006 04:17 AM
Heater Problem Jiim 1st Generation (1995.5–2004) 1 12-16-2005 05:26 PM
