EGR valve ? ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2006, 03:25 PM   #1 (permalink)
View michoujordan76's Photo Gallery
EGR valve ? ?
Hi All,
The check engine light in my 91 Camry comes on from time to time so I took it to the dealer. They said that it is caused by the EGR valve and that it's not worth changing given the age of my car.
I like my car and would rather keep it in good running order than wait for it to die from neglect. So, what does this EGR thing do and should I fix it?
Plus this car is originally from California; can I use a regular part or will that cause a problem?
Thanks for your help!
michoujordan76 is offline   Reply With Quote
Old 10-23-2006, 06:55 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The EGR valve is used to meter small amount of exhaust gases back into intake manifold during slow acceleration or steady cruising speed. The purpose of EGR is to lower combustion temperature by diluting the mixture. As a result of lower temperature, the Oxides of Nitrogen are forming in much smaller amounts then without EGR. In addition, use of EGR system allow to use regular grade gas without detonation and/or pre-ignition. However, the intake charge dilution lowers the power output and fuel economy.
The system on your car consists of EGR valve, vacuum modulator (aka back pressure sensor), bi-metal vacuum switching valve and vacuum hose. Starting 1989, the thermistor is screwed into the EGR valve, that sends the analog signal to the computer,and if EGR gas flow is low due to the valve or passage restriction, the temperature will also be low, therefore computer will set code 71.(Make sure that this code is displayed)
The most common EGR problems:
  • defective vacuum hoses
  • carbon blocking valve-to-intake manifold passage - remove and clean
  • ruptured diaphragm in the modulator
  • broken off vacuum switching valve
  • plugged vacuum signal ports in the throttle body
Doctor J is offline   Reply With Quote
Old 10-23-2006, 08:14 PM   #3 (permalink)
View toyomoho's Photo Gallery
Could be carbon build up, owners have had success at removing the valve and cleaning it. Getting a California part should not be a problem, check costs first. One reason to clean the valve if possible.
Old 10-23-2006, 09:16 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
simply put a bolt in the vacuum line that goes to the valve and be done with it, ive done this to all mine, if it pings, just back the timing up slightly, your mpg will go up too
Old 10-30-2006, 02:26 PM   #5 (permalink)
Thanks for all the detailed help.
I read on the web that a faulty egr valve can cause rough idle and stifled acceleration.
What say you?
Old 10-30-2006, 02:38 PM   #6 (permalink)
Doctor J's Avatar
If EGR stays partially open due to internal corrosion, the answer is yes
If the recirculation never take place due to plugged valve or passage, the car will actually get better accelerating power and fuel economy, but may ping due to higher combustion temperature.
Old 10-30-2006, 08:47 PM   #7 (permalink)
NYR
View IvanHoe's Photo Gallery
Do you have any pics?, Id love to do this!
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 10-31-2006, 10:02 AM   #8 (permalink)
View marc780's Photo Gallery
Junkyard part is an option. Smog check is tough here so blocking it wouldnt work for me - if no smog where you live, id try and do what fred said, for a temporary fix,
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
EGR valve '96 ES BobES300 General Lexus Discussion 0 11-16-2005 08:44 AM
1990 Camry 3sfe EGR valve Kep 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-29-2005 10:33 AM
egr valve replacement write up TheRyanator Camry & Solara Lounge 2 12-14-2004 09:07 AM
EGR Valve _VVTi_ Camry & Solara Lounge 21 10-11-2004 10:35 AM
