problem.. shifting gears - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2006, 07:39 PM   #1 (permalink)
View rockhard's Photo Gallery
when I am shifting gears either accelerating or deccelerating ,.. I step on the clutch, it goes down easily but the problem is that when I move the shifter into the next gear I have to push it fairly hard before it pops into position.
the gears arent grinding and it has never done this before
what could it be??
rockhard is offline   Reply With Quote
Old 10-25-2006, 09:53 PM   #2 (permalink)
ApexiCamry
View DiscoPotato's Photo Gallery
Have you checked your brake fluid on your clutch? If that's not the problem, then it's probably gonna be a transmission problem...
DiscoPotato is offline   Reply With Quote
Old 10-25-2006, 10:12 PM   #3 (permalink)
View toyomoho's Photo Gallery
How does the trans shift with the engine off and clutch pressed? When driving, does the hard shifting occur in all gears or just say 2nd?
Old 10-25-2006, 11:27 PM   #4 (permalink)
the brake/clutch fluid is full and a little while ago I replaced the slave cylinder for the clutch.
it mainly happens with the 3rd and 2nd gear but 3 works better
and it shifts easily when the car is off
Old 10-26-2006, 02:16 AM   #5 (permalink)
A few things to check: clutch pedal free play should be 0.20- .0.59 inch, the slave cylinder is moving the clutch fork the full amount when the pedal is pressed. Might try bleeding the system again.
Old 10-26-2006, 04:21 AM   #6 (permalink)
Beams SV21
da_horse's Avatar
View da_horse's Photo Gallery
sounds like your synchros are a bit worn. might be worth changing the transmission fluid with some synchromesh
Huy
1989 BEAMS 3S-GE SV21 Camry
da_horse is offline   Reply With Quote
Oil sludge problem solved? NoCVT Camry & Solara Lounge 7 04-22-2008 05:51 PM
'96 Landcruiser Ignition Problem Zog Land Cruiser Forum 0 02-20-2006 10:03 PM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
