Engine removal 1990 ES250 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2006, 02:09 PM   #1 (permalink)
View vtj2325's Photo Gallery
I am trying to R/R the engine in my daughters 90 ES250. I have it striped down to the
short block and all bolts removed. I would REALLY like not to have to remove the transaxle.
I cannot seem to get the engine and tranny to separate 1/2 inch maybe. (Automatic). what am I missing..
Have I missed something about unbolting the torque converter??? and if so what? and how do I get to it. ....maybe the starter hole???
I got a Great Deal on a reman short block and this could work out to be a Sweet job if I was not such a idiot.
Any help ....Please.
T.
vtj2325 is offline   Reply With Quote
Old 10-31-2006, 02:34 PM   #2 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Have you actually unbolted the torque converter from the flywheel? This is done by removing the inspection cover on the underneath/face of the tranny and rotatiing the crank at intervals to expose the bolts. There are 6 of them. Other than that, if all the ancillery mounts and driveshafts etc etc..then it should seperate.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 10-31-2006, 03:30 PM   #3 (permalink)
Thanks!
Thankyou..
Can the engine alone be removed ok?? you said something about disconnect the drive
shafts....
T.
Old 10-31-2006, 06:47 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
there is a drive shaft support bracket on the back of the motor
Old 03-14-2007, 12:05 PM   #5 (permalink)
finally done.
I had that support bracket turned the wrong way when I reinstalled the motor ,
it is unable to rotate all the way around without hitting the pan on the bottom or the exhaust manifold on the top. SOOO now I guess I have to disconnect the axle to swing the
bracket. BUMMER.
Do you know of a quick way to besure the new oil pump is working..I am not so sure I trust
the idiot light on the dash. I worry that every noise in the valves is "not enough Oil" .
Thanks!!
Old 03-14-2007, 04:15 PM   #6 (permalink)
VeeZed
Fit an oil pressure guage in the thread where the stock oil sender switch is (just next to the oil filter)...start the motor and then see what the oil pressure is. If its within specs then all good. (sorry dont have teh specs on me atm)
Old 05-01-2007, 02:58 PM   #7 (permalink)
1990 ES250 Lexus
I like this!! New problem does anyone know about a flashing "O/D OFF" light on the dash and a Speedometer that does not work. yesterday speedo worked fine and no flashing light.???
Is the Speedo cable broken?? thoughts..
thanks,
troy
Old 05-01-2007, 07:28 PM   #8 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
likely the cable is broken, or unhooked. flashing o/d light indicates a transmission problem, but i think ive had one flash that just had the cable broken.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 05-05-2007, 05:16 PM   #9 (permalink)
View monito's Photo Gallery
Originally Posted by vtj2325
1990 ES250 Lexus
thanks,
troy
check speedo gear that goes into AT
monito is offline   Reply With Quote
Old 05-05-2007, 07:00 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
speedo cable
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
20R ENGINE REBUILD FROM HELL! (Part Three) nwdetectorist Pre-88 Toyota Pickup/Hilux 1 08-09-2007 07:30 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
engine removal pics djprefix Camry & Solara Lounge 4 02-04-2003 12:21 AM
