Help! ignition timing question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2006, 08:03 PM   #1 (permalink)
View rockhard's Photo Gallery
my ignition timing is way off right now and my car is running very rough. since I put the whole distributor back on it hasnt been firing properly..
so my question is what way is the rotor supposed to point when the engine is at TDC?? . . cyl 1 or cyl 1 contact, cyl 2 or cyl 2 contact etc....
I cant really drive it like this and I need my car for tomorow
Any Help is apprieciated Thanks!!!
rockhard is offline   Reply With Quote
Old 11-02-2006, 08:09 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
How many degrees approx is your timing off? Have you shorted T and E1 trminals in the diagn. box prior to checking the timing?
Doctor J is offline   Reply With Quote
Old 11-02-2006, 08:56 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
When cylinder #1 is at TDC on compression stroke, the rotor should point to #1. Make sure its at TDC on compression stroke, not TDC on exhaust stroke.
TDC on compression stroke =
1. Oil seal retainer mark aligned with the center of the small hole on the camshaft timing pulley.
2. Mark on crank pulley aligned with "0" mark on lower timing belt cover.
http://autozone.com/servlet/UiBroker...3d8013e3a4.jsp
"Skoolin' the unlearned!"
Old 11-02-2006, 07:08 PM   #4 (permalink)
well i tried adjusting and re-adjusting the ignition timing, and right now its as close as it is going to get and it is still mis-firing, I recently had just changed the timing belt could the cause be something to do with that, like the camshaft not being marked off properly
Old 11-03-2006, 07:32 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Yes.
Check the alignment of the cam and crank.
Old 11-03-2006, 05:31 PM   #6 (permalink)
that will be the next thing I do
Thanks!
Old 11-05-2006, 04:07 PM   #7 (permalink)
ok well Ive realigned the crankshaft and camshaft and set the dist rotor to #1 but the car wont even start now, the engine only turns over but doesnt start.
I aligned the camshaft pully is on its 0-mark with the small hole on the camshaft pulley
and pointed the crank pulley mark to the 0 on the timing indicator then put the timing belt back on making sure that none of the pulleys moved
I really need to get it running and I may take it to a mechanic but that would be a waste if I could do it myself
anyone know what I may have done wrong?
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 09:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
