Sticky Throttle Body - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2006, 06:32 PM   #1 (permalink)
View 89Camre's Photo Gallery
Does everyone else with the 87-91 4 cyl 5 speed have as much trouble as I do with the throttle sticking from crankcase gunk in the throttle body? Well...its not really that bad, but I do have to clean it out every 5 K...
89Camre is offline   Reply With Quote
Old 11-04-2006, 09:44 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
i bet the throttle body is worn out?
Old 11-04-2006, 10:08 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I have the same problem with the tb on my 5-speed V6. I have to clean it every 3 to 4 months, or else the throttle sticks. My throttle body is slightly worn-out, but I don't think that's the whole story. I've noticed more blow-back oil in the tb, at the butterfly valve, and I think it's sneaking-in from the crankcase. Does anyone care to weigh-in on this theory? Could a leaky gasket on/in the crankcase or valve cover cause this problem?
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-10-2006, 02:13 PM   #4 (permalink)
View marc780's Photo Gallery
There are several posts on this site for an easy fix for this the TBI and plenum getting dirty inside; the fix is to splice in a cheap, clear in-line fuel filter into the vacuum line between the valve cover and plenum. And the filter will catch most of the oily gases from the engine. And then hopefully you will not have to clean it so often.
I think the problem is there is a little bit more blowby from a used engine, but if it runs ok and passes smog, so what? Even brand new engines have SOME blowby (due to gap in rings!) and so nothing to worry about, to me.
Old 11-13-2006, 07:17 PM   #5 (permalink)
Bullitprooph
Awesome idea, I'll try that filter idea. Thanks...
Old 11-14-2006, 08:01 AM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Just make sure that idle PCV passage that opens up on the other side of throttle plate is clear.
Doctor J is offline   Reply With Quote
Peel out after cleaning throttle body? Blackhawk3D Camry & Solara Lounge 40 04-03-2007 07:01 AM
throttle body specs WickedLexus96 Camry & Solara Lounge 0 12-19-2005 08:47 AM
Question with regards to the throttle body Ghost Archived Corolla threads 0 10-05-2005 03:19 PM
Throttle Body Problem? ghost99x MR2 Forum 3 10-04-2005 01:48 PM
