How to adjust idle speed on a '86 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 10:38 AM   #1 (permalink)
View atikovi's Photo Gallery
I got the engine back together in this car and got it started this morning. It runs great except the idle speed is at 1400 rpm when warmed up. How do you adjust it? I thought is might be this white screw (circled):
but nothing happens when I turn it 3 turns all the way in. I already set the timing properly.
atikovi is offline   Reply With Quote
Old 11-07-2006, 10:59 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
No, this screw is for a/c idle-up speed. The idle adjustment screw is under rubber plug on the throttle body.Note: do idle adjustment after the engine warms up, otherwise check the idle air bypass valve.
Doctor J is offline   Reply With Quote
Old 11-07-2006, 05:13 PM   #3 (permalink)
Gameroom cash: $302555
Doctor J has got it. It's to the right of your picture as we are looking at it. It's on the right of the throttle body as you are looking at it from the driver's side fender, in a vertical tube-like structure. There should be a rubber cap covering the screw. The screw is slotted. From memory, you turn the screw in to decrease the idle.
Mike
Mike Gerber is online now   Reply With Quote
Old 11-07-2006, 05:16 PM   #4 (permalink)
Found it, thanks.
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Idle Speed Problem 1998 Camry 4 Cylinder/Auto cdlubbe 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-26-2005 08:24 AM
