Thanks man and if it helps, Ive figgured out that the light comes on when I remote start the car, put the key in so I can drive it, and then when I go to put it into gear, the light comes on. The weird thing is it only comes on about 1 out of 5 times, but then it stays on. I really dont think it would matter but theres two 12 volt constant wires that go into the remote start, I ran them both to the same 12 volt constant wire at the ignition harness (the white one wire) You think maybe I should run one to the white and the other to the white and red? Maybe its too much power for that one circuit (just a thought)
