check engine light lean and misfire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2006, 12:17 PM   #1 (permalink)
View rflexible's Photo Gallery
Our 99 solara sle has been in the garage four times trying to fix the check engine light. after a repair and driving 8-10 miles we still get the codes for P0171 System too Lean, and P0301 Misfire Detected - Cyl. 1, P0302 Misfire Detected - Cyl. 2, and P0303 Misfire Detected - Cyl. 3
the dealer has replaces battery, plugs, and coil packs. and they let it sit overnight with battery disconnected to reset and recalibrate sensors. the light came on again. before we take it in again I'd like to identify what should be checked next.
rflexible is offline   Reply With Quote
Old 11-09-2006, 03:37 PM   #2 (permalink)
Gameroom cash: $302555
First of all, if you are going to post this in the Camry forum, you would be better off posting it in the generation 3 and 4 forum.
If I were to do anything, I would start by replacing the spark plug wires myself and see if that fixes the misfire codes; P0301, P0302, etc. The dealer has replaced all the other basic ignition components.
After replacing the plug wires, you can get the codes read and cleared for free at your local Autozone. Then drive the car and see if any of the codes return.
Mike
Mike Gerber is online now   Reply With Quote
Old 11-09-2006, 08:28 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
look for a vacuum leak
Old 11-21-2006, 10:40 AM   #4 (permalink)
View joandjo's Photo Gallery
Clean your MAF sensor.
1992 Toyota Camry LE, 3vz-fe, 254K mi, still going strong...
joandjo is offline   Reply With Quote
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
