Idle issues - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2006, 09:56 AM   #1 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
Idle issues
89 4cly camry
Car idles high when cold, nearly 2k rpm, when it warms up it drops to about 900-1000, which im told is a tad high too, although it seems to run a bit rough at 900, but smooths out around 1100.
Which sensor do i need to replace and where is it located?
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 11-17-2006, 08:49 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
screw under rubber plug after you clean up things
Old 11-17-2006, 09:48 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
^ To expand on what Fred said, which didnt make too much sense,
Clean up the throttle body and IAC (which is on the throttle body) and then locate a small rubber cap on the top of the throttle body. When you remove it you will see a screw, which you can use to adjust the idle speed. After you get it correct, dab a bit of nail polish on the edge of it to stop it from loosening off agian.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 11-17-2006, 10:03 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
tommy knows what i am talking about
Old 11-17-2006, 10:52 PM   #5 (permalink)
Tommy's Avatar
idle screw is all the way down, hasnt moved, cant go any slower.
My garage
Old 11-17-2006, 11:58 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
check the egr valve to see if it shut and start looking for a vacuum leak
Old 11-18-2006, 05:33 AM   #7 (permalink)
VeeZed
Indeed, but does the rest of the TN community? This isn't PM :P
Old 11-18-2006, 07:58 AM   #8 (permalink)
NYR
View IvanHoe's Photo Gallery
Faulty EGR valves often trigger the CEL, but it's a good place to start.
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 11-19-2006, 09:01 PM   #9 (permalink)
View Flight23's Photo Gallery
2nd Generation screw
just wondering does the v6 88 have an adjustment screw and if so where is it located
pics would be great
Ta
Flight23 is offline   Reply With Quote
Old 11-19-2006, 09:07 PM   #10 (permalink)
VeeZed
No idle adjustment on the V6...all is controlled by the ECU.
You can cheat however and adjust the stop screw to hole the throttle open...but its not really the right way.
Idle issues! Cutsman Celica Forum 4 11-15-2006 07:32 PM
1996 4cly Idle issues mikesgt5 3rd & 4th Generation (1992–1996 & 1997–2001) 1 05-31-2005 05:23 AM
Idle issues....please help. SharpShooter34 Archived Corolla threads 4 11-13-2004 10:51 AM
Idle issues 87Camry5Speed Camry & Solara Lounge 7 03-27-2004 09:47 AM
