clutch problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2006, 04:10 PM   #1 (permalink)
View rockhard's Photo Gallery
clutch problem
ok the clutch on my camy is going bybye... when im cruising and its in gear and i step on the gas pedal hard it doesnt accelerate very well but the rpm goes way up. so what parts do I need to replace this problem with the clutch
thanks
rockhard is offline   Reply With Quote
Old 11-19-2006, 04:36 PM   #2 (permalink)
View marc780's Photo Gallery
It's a clutch job you need. The transmission has to come out, then the parts are exposed for replacing.
You need a clutch disc, a pressure plate, and a throwout (release) bearing. It usually costs about $400 - 500 to have this done, the parts alone with no labor but your own, are about half that, or less.
Old 11-19-2006, 05:29 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
yep, the clutch went bye bye
Old 11-19-2006, 05:46 PM   #4 (permalink)
View toyomoho's Photo Gallery
Also check the flywheel to see if needs resurfaceing.
Old 11-21-2006, 06:49 PM   #5 (permalink)
NYR
View IvanHoe's Photo Gallery
Right!!!! good time to have your flywheel resurfaced
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 11-21-2006, 11:28 PM   #6 (permalink)
I found out what it was! apparently it is just the clutch plate, and its over-heating. because it only starts to slip after I drive it hard for a bit. maybe im a bit low on tranny fluid or somethin?
Old 11-22-2006, 01:50 AM   #7 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Well, heat is definitely your clutch's worst enemy...but if it's slipping at all, you need to replace it. Simple heating from "hard driving" shouldn't be enough to cause it to slip like that. Get it replaced soon, or you'll be down to the plate rivets and you'll trash your flywheel. Kinda like dominos, you have to fix it before it causes more damage.
Old tranny fluid will not cause such a severe problem. But replace it anyway...it can't hurt.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 12-17-2006, 12:12 PM   #8 (permalink)
You need to replace the clutch. All three parts, pressure plate and throwout bearing too, i would never just change the disc. I tried that trick once, when i was broke, i just changed the fruiction disc on my old Chevy Vega, and the pressure plate failed soon after and i just had to do it all again. Yuk! :-P
The only possible wrinkle is if the rear main seal is leaking oil on it too. But i'm betting it isnt leaking, because you would have mentioned an oil leak or smelly clutch.
If you had to though, alot of times you could change this seal without removing the engine or crank but the transmission has to come out. Which it will be of course when you are changing the clutch. At this point it would be painfully obvious if the rear main is leaking or not because of all the oil that would be in there when you yanked the trans out.
Clutch pedal position problem cptcrush 2nd Generation (2005+) 7 08-14-2005 01:42 PM
clutch problem MR2Jedi MR2 Forum 18 07-12-2005 12:16 AM
clutch pedal problem - 05 tacoma drg 2nd Generation (2005+) 1 05-28-2005 09:25 PM
clutch problem ? jslnitroclicks Yaris, Vitz and Echo Forum 0 12-16-2004 02:56 AM
'94 Clutch Problem Ostornadoe Archived Corolla threads 4 12-13-2004 05:50 PM
